Author Topic: New version won't start!  (Read 5318 times)
goldeneye12r
« on: August 21, 2007, 04:33:36 AM »
As you can see I am new here. But I am not new to homebrew. I just updated from 3.40 OE to 3.40 Leaked Edition by wildcard team. I have used every version of your emu, but my problem is with the birthday edition. I have put my amiga kickstart rom into "KICKS" like usual, named "kick31.rom", then put games into disk folder. I try to start it up, but no luck it just gives me the "Amiga, our past, present and future" icon then freezes my psp and shuts off! Please help!  ???  :'(
Re: New version won't start!
« Reply #1 on: August 21, 2007, 11:01:28 AM »
Well, its not the firmware if you can at least start PSPUAE. Its sounds like it is most likely your kickstart, but you seem to have named it correctly and put it in the right place, so I'm not sure. Do you have a 1.3 kickstart rom you can use as well? If so, then name that kick13.rom and stick it in the KICKs folder along with your kick31.rom. I believe that PSPUAE looks for the 1.3 kickstart on start-up and so that could be your problem.
*EDIT* I just read through the installation guide, something which you should have read first before posting ;) , and it states that you MUST have the 1.3 kickstart in the KICKS folder or else PSPUAE won't start *EDIT*
« Last Edit: August 21, 2007, 11:04:48 AM by skateblind »
« Reply #2 on: August 21, 2007, 05:11:57 PM »
Did skates answer solve your problem?
