Pages: [1] 2 3 ... 5   Go Down
Author Topic: SWOS RISS  (Read 60706 times)
zicozico
SWOS RISS
« on: August 22, 2007, 04:57:40 PM »
hi is it possible for a ram state file of swos with the new 2006/2007 updated data?
where is this data and i'd look into it
Career mode crashes with the SWOS savestat uploaded here (at selecting your team).
Looks like the savestate is not 100% correct.
Can someone correct the SWOS 96/97 savestate?
I'd really like to play SWOS career mode again!!
By the way SWOS 05/06 update would be here:
http://www.eibmoz.dk/swos0506/index.php
SWOS State Problems
« Reply #1 on: August 22, 2007, 05:10:34 PM »
Turn CPU Cycle Exact to "ON". That should correct the problem, then save the config for that state.
zicozico
SWOS State Problems
« Reply #2 on: August 22, 2007, 06:58:16 PM »
HI
Thanks for the answer.
Sorry to bother you again but there's no CPU cycle exact to "on" in version 0.63.
Only blitter cycle exact (which was "on") and a CPU setting "REAL", which I tried.
Unfortunately no luck yet  :-(
SWOS State Problems
« Reply #3 on: August 22, 2007, 07:59:30 PM »
HI
Sorry, thats the option i ment, :(.
Best to ask horace, as he made the state.
Re: SWOS State Problems
« Reply #4 on: August 22, 2007, 10:01:05 PM »
i will look into it next week when i have the chance.
i did test this when i made the state.... any chance the cycle-exact setting got broke?
maybe try immediate blitters instead?
zicozico
« Reply #5 on: August 23, 2007, 08:51:12 AM »
GREAT!!
Immediate blits seems to do the trick!
Brilliant!!
« Reply #6 on: August 23, 2007, 02:59:33 PM »
No, I didnt break Cycle Exact. Works fine for me.
« Reply #7 on: August 23, 2007, 05:03:13 PM »
well we have the answer anyway... it needs immediate blitters.
i had thought before they got swapped by accident... when i was testing Plutos, (which needs it) but it turned out i was confused about which one winuae needed. (as i recall, winuae-kaillera breaks with either imm. blitters or cycle exact)
maybe they were wrong originally and got fixed (i beleive they were added becasue i requested it for SWOS) - this might explain why the SWOS config is set up wrong... becasue i -would- have tested that.
« Reply #8 on: August 23, 2007, 10:15:43 PM »
tut tut, how we forget, i added Cycle exact, and your reply "Thanks FOL, I hate you sometimes, I sat up all night playing SWOS cause you added Cycle exact". It was deffo cycle exact that fixed it, and they have definately not swapped by mistake, cycle exact slows emu more than blitter.
« Reply #9 on: August 23, 2007, 10:25:07 PM »
Well, what ever it was/is, could we get a fixed save-state uploaded sometime please?
Cheers!  ;D
« Reply #10 on: August 23, 2007, 10:26:59 PM »
Cheers!  ;D
bah your just bored, cause you cant play outspark, ;). Tommorow should be fun though.
« Reply #11 on: August 23, 2007, 10:32:12 PM »
exactly my point!
it seems Immediate Blits fixes the problem NOT cycle exact. (according to zicozico )
my point is that when they were added in the beta, they were perhaps wrong. (i remember some fiddling being done with them, like ensuring only one was ever switched on at a time - it was likely then, that it was sorted) -
perhaps this is why it was later assumed (when making the state) that Cycle Exact was what was needed, when in fact Imm.Blits were needed.
whatever the case, one of them works, and when i tried Plutos recently, i got it working with the same setting as WinUAE, so things are definately right now ;)
p.s. skate:  it doesnt warrant a new state. why dont YOU update the config, test it and re-upload it for a change?! :P
« Reply #12 on: August 24, 2007, 04:04:19 PM »
OK,  I will  :P
*Salutes horace*
craigtumilty
SWOS 96/07 R.I.S.S
« Reply #13 on: September 16, 2007, 03:15:10 PM »
Ive managed to get the SWOS R.I.S.S. version on your site running on my psp
the thing is i wanted to use some custom tactics i have on an ADF but when i load the disk in they dnot show up?
ive tried running workbench on my pc using WinAUE and they show up fine just not when i goto load them in pspuae
Any Advice?
Thanks
Re: SWOS 96/07 R.I.S.S
« Reply #14 on: September 16, 2007, 03:17:03 PM »
Any Advice?
Thanks
Horace is the lord of everything SWOS, sure he will have the answer you seek, ;).
Pages: [1] 2 3 ... 5   Go Up
