Pages: 1 [2] 3 4 5   Go Down
Author Topic: SWOS RISS  (Read 60682 times)
Re: SWOS 96/07 R.I.S.S
« Reply #15 on: September 16, 2007, 04:56:47 PM »
they would likely require a new RISS made, which allows files to be transferred to/from ADF.
i'll look into it
craigtumilty
« Reply #16 on: September 19, 2007, 09:15:43 PM »
ah right
tried to use an adf loading version of swos but it freezes when i goto load from a ADF disk on tactics screen
shame cos the tactics ive got made all the players values rise loads
« Reply #17 on: September 19, 2007, 09:42:50 PM »
if you post your tactic file, i'll see if i can "inject" it into the current RISS for a less permanent solution.
Jefferio
Re: SWOS State Problems
« Reply #18 on: November 01, 2007, 06:02:32 PM »
sorry to trouble you guys but I'm having issues!
I'm new to this so this maybe a simple problem? I can use adf games no worries but swos is my 1st save state. I load save state and it freezes and psp turns off. I try to load the config file and it freezes and psp turns off again?! Please help this poor simpleton!  ;D
« Reply #19 on: November 01, 2007, 06:11:03 PM »
Im guessing you dont have KickROM 3.0.
Make sure you have both kickrom 1.3 and kickrom 3.0, naming then kick13 and kick30. Place them in the KICKS folder.
It should show an error message, but with 1.50 eboot, it crashes instead.
« Last Edit: November 01, 2007, 06:17:56 PM by FOL »
Jefferio
« Reply #20 on: November 01, 2007, 06:31:43 PM »
Easy as that eh?! Thank you, its working fine now. Just need to try n add this 05 06 update?
« Reply #21 on: November 01, 2007, 06:44:17 PM »
Dont think they are available, best to ask Hungry Horace
« Reply #22 on: November 01, 2007, 06:49:16 PM »
when i get the time, i'll do a proper SWOS update for pspuae.com
if you would like to post the 0506 (0708 would be better though :p  )  data here, i can use that with it.
Jefferio
« Reply #23 on: November 01, 2007, 07:14:38 PM »
well horace if u fancy creating a 07 08 update that would be great!!!! this 06 07 thing i got is a hdf file and i havent had it running tho so not sure how much udse it will be?
« Reply #24 on: November 02, 2007, 05:00:22 PM »
HDF is fine for extracting data from, it just cant be used direct with PSPUAE.
any update i do will be primarirly in the graphics dept. with data taken from elsewhere.
at most i might update Sheffield Wednsday, England and Chelsea, but that would be the lot... i haent time to get into data editting again.
Jefferio
« Reply #25 on: November 03, 2007, 05:07:07 PM »
how about manchester united as well?! I've started career mode now anyway, think I can live without updates. While I'm here I was wondering if theres a way to save highlights? Using a drive during savestate gameplay doesnt really work does it? I couldnt get it to work anyway.
« Reply #26 on: November 03, 2007, 05:57:03 PM »
there is no "save" adf included with the SWOS RISS, but it should be easy to create one. all "in-game" saving would go onto that. Easy to creat one in WINuae however (create formatted adf)  - and then you just use it like any other ADF by sticking it into the emulated DF0:
p.s.  there's not a hope-in-hell of >me< updating man united!! i hate them that much!
Jefferio
Re: SWOS RISS
« Reply #27 on: November 03, 2007, 06:16:58 PM »
well I'm a man utd fan so it was worth a try!  ::) yeah I have a saves adf already done coz I play a few other games using adf. when i go to save it goes to the amiga dos screen saying replace volume 1 in df0 in a system request box at the top but on main screen it says operation succesful? But I cant get off this screen and the save sdoesnt seem to work?
Re: SWOS RISS
« Reply #28 on: November 03, 2007, 06:40:07 PM »
might have a stab at making a new SWOS RISS tonight then, time permitting.
thanks for reporting this bug.
Jefferio
Re: SWOS RISS
« Reply #29 on: November 03, 2007, 06:43:48 PM »
That would be great. Wish I could help and do it myself but I wouldnt have a clue! Searched forums 1st before I asked but no ones reported a problem. Maybe I'm the only saddo who wants to save the highlights!
Thanks again horace
Pages: 1 [2] 3 4 5   Go Up
