Pages: 1 ... 3 4 [5]   Go Down
Author Topic: SWOS RISS  (Read 60673 times)
Re: SWOS RISS
« Reply #60 on: September 09, 2015, 05:39:19 PM »
Sorry, I can't be sure. It must be something to do with the teams pack from Syncronated if the other versions work ok.
I wonder if he changed he number of teams in the league or something, and it doesn't like it....
dawsonkamps
Re: SWOS RISS
« Reply #61 on: September 10, 2015, 07:43:02 PM »
Hello there! Actually, Hungry Horace, they changed the number of teams of a number of leagues; I guess that's why they changed the main files in the amiga and pc formats. Is there a way to make a RISS based on this modified version?
Re: SWOS RISS
« Reply #62 on: September 12, 2015, 09:42:09 PM »
The Riss *is* using that modified version? I simply inserted all of the files from the Syncronated download into the game.
ritchie
Re: SWOS RISS
« Reply #63 on: November 25, 2015, 05:31:05 AM »
Hi there,
I wonder if anyone can help? I've been playing the RISS version of swos 2013-14 (and loving it!) but when it gets to the end of a career season it goes to a black screen instead of continuing on. I tried it with a 2nd division scottish team first and this happened and then with an english premiership team - this was slightly different as it showed the league tables for the other english divisions and then went to a black screen. Any advice? I don't have any disks in the drive.
cheers,
r
EDIT So I gave up on trying to get the career mode to work properly and tried the SWOS96-97 RISS on 7.2. That didn't work either, and nor did a variety of adf files. However, the SWOS online version RISS for 6.3 seems to work with the career mode etc. The only thing is that it is quite a bit slower than the 2013-14 version - is that just the way it is or does anyone have the optimum settings for it they could share?
cheers,
r
« Last Edit: November 26, 2015, 12:55:51 PM by ritchie »
dawsonkamps
Re: SWOS RISS
« Reply #64 on: August 30, 2016, 07:53:24 PM »
Hello there! Since the 13-14 update didn't work as well as expected, I tried to rediscover the original 96-97, but I soon realized that without being able to edit tactics, the experience is just not complete; I've tried to format disks to save the tactics, but nothing works... it always ends up crashing. I ask you, lords of all things SWOS: is there a way to create a riss with a save disk, like the online version? Thank you for your time. :)
Re: SWOS RISS
« Reply #65 on: September 24, 2016, 07:26:39 AM »
I will look into the when I have a couple of other RISS to do soon.
Couple of projects I need to shift first tho
dawsonkamps
Re: SWOS RISS
« Reply #66 on: November 03, 2016, 10:05:01 PM »
Thank you very much for your attention. Your work is definitely amazing, man. Looking forward to the new SWOS riss.
lordofdogtown83
Re: SWOS RISS
« Reply #67 on: May 04, 2020, 12:30:51 PM »
hi,
i've downloaded the RISS for SWOS 96/97 and it's loading, but it isn't detecting the fire buttons
i've checked the controller set up under the psp section within pspuae and it says that X or O is the fire button for joystick 0 but it's still just cycling through the credits.
Cheers
Gaz
Re: SWOS RISS
« Reply #68 on: May 24, 2020, 08:10:06 PM »
Surely Joystick 1 is what you need? Joystick 0 is probably the mouse port.
It's been a long time since i've used PSPUAE, but i assume this is correct, in line with the other emulators
Pages: 1 ... 3 4 [5]   Go Up
