Author Topic: PSP Slim custom firmware  (Read 26916 times)
kixs
Re: PSP Slim custom firmware
« Reply #15 on: December 08, 2007, 10:26:22 PM »
Hi there!
So how is PSP Slim and PSPUAE going along?
I've read some info on this forum, but nothing new. So are there still slowdowns or some other problems?
I'm planing on buying PSP Slim (cfs 3.71m33-3) mainly to play different Emulators on it... Amiga included   :D
Or would it be wiser to buy PSP Fat?
Thanks!
« Last Edit: December 08, 2007, 10:31:10 PM by kixs »
« Reply #16 on: December 08, 2007, 10:45:08 PM »
Hi there!
Thanks!
Current PSPUAE, runs fine with slim. A new version of PSPUAE is still being worked on.
kixs
« Reply #17 on: December 08, 2007, 11:33:02 PM »
Thanks a lot  ;D
Keep up the great work!
« Reply #18 on: December 09, 2007, 12:05:22 AM »
Thanks a lot  ;D
Just let me know, when you get your psp and get it hacked, then ill hook you up with eboot you need, to make it as painless as possible. All you need then is the kickroms.
kixs
« Reply #19 on: December 09, 2007, 12:37:11 AM »
PSP is all new to me... but otherwise I have many years (10+) of emus experiance... WinUAE included  ;)
Help is appreciated.
The Evolution Of Life
« Reply #20 on: December 13, 2007, 04:55:49 PM »
I've made a PSP Slim version myself by just simply removing the un-needed crap from the GTA Package.
It works on 3.73HX "The latest CF which doesn't support 1.5" (Tested on Fat).
Can't upload it though, it has Kickroms, just make it yourself.
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
« Reply #21 on: December 13, 2007, 05:05:17 PM »
As I said in chat box, what your using is exactly the same as the normal release (1.00 Eboot).
Harrison
  • classicamiga.com
  • PSPUAE Affiliate
    • Classicamiga.com
« Reply #22 on: December 14, 2007, 11:58:14 PM »
With the current 3.7X CFW versions you can install the Dark AleX 1.5 Kernel plugin which adds support back for the older 1.l5 kernel to get emulators and other homebrew to work again, so now the Slim PSP has the full functionality back that the Fat PSP owners have had.
Admin of classicamiga.com
