Pages: 1 2 [3]   Go Down
Author Topic: Due For A 3xx Homebrew Protocol Kernel Update  (Read 33047 times)
The Evolution Of Life
Re: Due For A 3xx Homebrew Protocol Kernel Update
« Reply #30 on: October 12, 2007, 08:36:09 AM »
So that brings back up the fact that no other CPU's work exept from 68000, which could be the reason for the ongoing AGA Chipset problem.
You should try testing AGA on the slower but only working CPU "68000" if thats at all possible before reporting that even basic AGA support doesn't work.
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
« Reply #31 on: October 12, 2007, 11:54:29 AM »
HUH????
All cpu's work fine. So you have lost me completely.
« Reply #32 on: October 12, 2007, 05:22:14 PM »
fol is right, all cpus work.
otherwise some of the RISS wouldnt exist. (68020 is required for some of them)
its just that anything above 68000 wasnt liked by whatever you were trying to run on an a500+ mode. that's the software's fault, not the emulator's.
webhead
« Reply #33 on: October 28, 2007, 04:06:52 PM »
hi everyone what a great emulator many thanks for making it.
i just like to say at first i couldnt get it working on my 3.52 M33 firm.
but i then put the version 1 on instead and it now workd fine.
just thought id say as people cant seem to load 1.5 like me.
many thanks to everyone.
« Reply #34 on: October 28, 2007, 04:46:53 PM »
As I have always told people, its even in all the guides, use V1.00 eboot on Custom Firmware, :). Thanks for the comfirmation post, :).
Pages: 1 2 [3]   Go Up
