Author Topic: REQ: 3 quick feature requests  (Read 5181 times)
andrewwan1980
« on: October 17, 2007, 03:47:55 PM »
1. Regularly my PSPUAE crashes when am tweaking settings just to get PSPUAE to run the fastest/max best. I hate having to wait for PSPUAE to load up and see the front title all the time. Could we implement faster/immediate PSPUAE loading to the menu?
2. AGA support for AGA games.
3. intelligent recognition system for games. such as knowing whether a game supports A500 or A1200. would be great instead of leaving us newbies having to test & try UAE settings just to get one game working... then having to remember best settings for specific games...
Re: REQ: 3 quick feature requests
« Reply #1 on: October 17, 2007, 04:15:10 PM »
1, load the game, then press select, then savestates, then save.
2, Not even going to answer this, fed up of this question now.
3, hmmmm, hence the default configs, A500, A600, etc etc in configs. You are resetting the emulator after changing configs, right? Once you have a running, just save a config for it, and it will remember everything the next time you load that config.
4, no effence, i know your new, but everything you are asking has already been answered time and time again. Its getting annoying, search should find everything you need answered.
Plus, im the only 1, working on PSPUAE at the moment (aint heard from any of devs, apart from gnostic). So it will take longer, also im without my deving PC, so i cant do jack even if i wanted to.
EDIT:- Miss read original post, right, locate the GUI folder and rename or delete the 2 pic files, then you will be able to use 10.5mb mem, that will also stop the title pic loading up.
« Last Edit: October 17, 2007, 11:37:57 PM by FOL »
