Author Topic: Best way to install updates?  (Read 6166 times)
ParaSitius
  • Swish
    • ParaSitius.com
« on: July 20, 2006, 09:18:22 PM »
In anticipation of 0.52 I was wondering what is the best way of installing it on my psp.
Should I just remove 0.51 (after moving the DISKS folder first) or can I just overwrite the current version?
Re: Best way to install updates?
« Reply #1 on: July 20, 2006, 09:22:01 PM »
just overwrite the old eboot in the %__SCE__PSPUAE folder and same with __SCE__PSPUAE.
That should be it. other than that, copy the 2 folders across over writing everything.
Exoskeletor
  • PSPUAE Site Staff
« Reply #2 on: July 20, 2006, 10:24:19 PM »
and copy every files that savestate folder have in the new state folder
Live And Let Die
Amiga Will Never Die PC User
« Reply #3 on: July 20, 2006, 10:28:17 PM »
Good call, I missed that 1, thanks, ;)
