Author Topic: PSPUAE 0.52 Released  (Read 20738 times)
« on: July 20, 2006, 09:26:13 PM »
Hi, Ric has released the latest version (0.52), heres the changes,
This is a Maintenance Release to Fix some Bugs
v0.52 - maintenance release
- Corrected 0 byte memory bug when loading/saving options
- Renamed the SAVESTATE folder to STATE
- Added 5 additional savestate slots
- Corrected some text strings
« Last Edit: November 13, 2006, 08:04:51 PM by FOL »
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE 0.52 Released
« Reply #1 on: July 20, 2006, 09:59:09 PM »
Thanks for the update Ric and FOL for making it available to download.
Gerd
« Reply #2 on: July 21, 2006, 06:54:41 AM »
HI nice work .. but i like Gina Sisters ist very hard to play it JUMP with the Controller up do you can make it JUMP with x ?
Sorry for my Bad English its not my language ;) i came from Germany ;) i hope you understand me
Hai
  • compute + compose
  • audio, video and stage artist
    • THE DUNGEON
« Reply #3 on: July 21, 2006, 08:35:25 AM »
Thanks alot Ric!
I have some problems though, UAE won´t load, just sends me back to XMB. I notices that the files STATE and DISKS are empty files (not drawers). Maybe it is something with OSX, will try on XP later.
EDIT: I forgot to put a kickstart file!
« Last Edit: July 21, 2006, 08:54:30 AM by Hai »
A1200, Blizzard 68060 (clocked to 66mhz), Melody PRO audioboard, 16mb fast, 850mb HD, SCSI cd-rom
PSPrulez
« Reply #4 on: July 21, 2006, 08:56:53 AM »
Great work! A new version! Works fine over here!
Keep it up!
Greetz,
Marco
« Reply #5 on: July 21, 2006, 11:40:57 AM »
Not sure, but if jump is done with up, try switching the joy 1 to analogue stick. I do this for turrican, much easier to play then. Other than that, if there is a keyboard button for jump, then change x to that keyboard key.
« Reply #6 on: July 21, 2006, 12:00:48 PM »
coulda sworn i posted already....
no one else having trouble with button -> keybaord mapping?
played briefly last night and could only get the OSK to work for the F-Keys on Cybernoid (which runs great btw)
havent tested other stuff yet, but i am away for the weekend and will be taking the PSP with me!
« Reply #7 on: July 21, 2006, 12:34:26 PM »
im working again my same settings ..kickrom 3.1, and 68020, sound =stereo ,frame skip =2
and it work perfect for now.. :-*
THANKS to RIC  for updates (and for 10 save slot!)
Hai
  • compute + compose
    • THE DUNGEON
« Reply #8 on: July 21, 2006, 12:51:13 PM »
Some questions:
Anyone here know which is faster, ECS or OCS?
I use Ibrowse on my Amiga, but I don´t find it very compatible. Is there a better one?
« Last Edit: July 21, 2006, 12:53:53 PM by Hai »
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #9 on: July 21, 2006, 01:03:37 PM »
Having probs here trying to get Pinball Dreams to work with keymapping.
Total madness to get the flippers to work.  Here's how the keymapping is.
Sqaure - Keyboard
Triangle - Down Arrow
X - Left Amiga
Circle - Left Mouse Button
Left Shoulder - Left Alt
Right Shoulder - Right Amiga
To get the flippers to work, I have to hold down a combination of 3 buttons.
Left Flipper - X, Triangle and Left Shoulder
Right Flipper - X, Left & Right Shoulder
Only way I've figured out to get the plunger to work is to just use the keyboard (which isn't a big problem).
I'm probably missing something obvious but damned if I can see it.
« Reply #10 on: July 21, 2006, 01:07:58 PM »
Sqaure - Keyboard
X - Left Amiga
I would test it now in work, but thats 1 game I aint got installed, :(. Cant connect PSP to work computer cause then something might be said, lol
« Reply #11 on: July 21, 2006, 01:09:14 PM »
Some questions:
Wouldnt have thought it would make much difference, but OCS is the earlier chipset I believe so I would go for that.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #12 on: July 21, 2006, 01:12:15 PM »
The mapping I done for PD was kind of random as I was just trying to see if one of the other buttons aside from the shift keys would work (game uses Shift/Alt/Amiga keys).
« Reply #13 on: July 21, 2006, 01:15:38 PM »
Nice feature would be CD32 controller mapping, then if hdf worked, cause use the CD32 version.
Feark
  • HE JUST LEFT....WITH NUTS
« Reply #14 on: July 21, 2006, 01:41:24 PM »
Thanks! This is great, the new savestates was needed.
