Author Topic: rom file browser  (Read 7812 times)
iqcumber
rom file browser
« on: July 20, 2006, 11:10:43 PM »
just a quick one. having to scroll all the way down to the bottom of the rom browser to get to newly added roms is a bit of a pain, especially for multi-disk games. A faster way, like left and right on the dpad for page up or page down, or some kind of sorting ability (alphabetically, date modified) would be good.
cheers.
Re: rom file browser
« Reply #1 on: July 20, 2006, 11:21:14 PM »
left and right shoulder buttons, make it scroll really fast, and by rom you mean ADF?
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #2 on: July 20, 2006, 11:28:41 PM »
Didn't know about that.
Where's that readme I asked for that explains everything about the Emu?
Blooming slacker  :P
* ParaSitius runs and hides
« Reply #3 on: July 20, 2006, 11:34:30 PM »
Blooming slacker  :P
I knew some smart a**e was going to say that, and again your thinking what im thinking, stop it, lol, your scaring me, lol.
I was thinking about that option explanation in work today. Need to finish this DB first I started it first.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #4 on: July 20, 2006, 11:51:08 PM »
Smart arse, psychic and part-time stalker at your service.
I'll let you off this once mind you as you are doing a grand job of updating the database.
iqcumber
« Reply #5 on: July 21, 2006, 02:37:24 AM »
Thanks for that tip, shoulder buttons work a treat.
And yes, rom = adf. Emulation is so much fun!
ric
  • PSPUAE DEV
  • PSPUAE Moderator
« Reply #6 on: July 21, 2006, 06:05:34 AM »
If you want to unserstand the options then read the configuration.txt file in the docs folder of the source distribution. Be aware that even though not all options are available in the PSPUAE options menu you can use all options if you create a config.uae file in the PSPUAE folder.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #7 on: July 21, 2006, 04:20:09 PM »
I've downloaded two of the files that say they include source code.
0.41 has no Docs folder and the 0.49 file only contains a single eboot file.
ric
  • PSPUAE DEV
  • PSPUAE Moderator
« Reply #8 on: July 21, 2006, 05:14:52 PM »
When FOL releases the 0.52 source on this site the file is part of that package. In the mean time just get it from the original e-uae source here: http://www.rcdrummond.net/uae/e-uae-0.8.29-WIP2/e-uae-0.8.29-WIP2.tar.bz2
« Reply #9 on: July 21, 2006, 05:27:54 PM »
Aye, ill up it now to downloads.
