Author Topic: Trouble running a game  (Read 6084 times)
hildand
« on: January 14, 2008, 08:56:39 PM »
For christmas I got the Psp with amiga-emulater installed. It should have "super frog" installed, but I can't find it on my psp. I found it when i connected the psp to my computer. It was under "disks", and was four adf-files. When i go to stats on my psp, it is emty. Anybody?
PS: I have a pspuae 0.63 BE
« Last Edit: January 14, 2008, 09:02:29 PM by hildand »
Re: Trouble running a game
« Reply #1 on: January 14, 2008, 09:52:19 PM »
Hi, how are you using those adf's?
Are you going to the floppies menu and inserting them?
You could try the savestate in the downloads section, under S. Its a simple quick way to run games, without the need for adf files.
« Reply #2 on: January 14, 2008, 11:20:57 PM »
he has said that he has the game as ADFs in DISKS/, but when he goes to "load states" he cant find them... either he needs to load the game from ADF using "insert disk"  or, as you said FOL, he needs to install the RISS version, and then load the state.
« Reply #3 on: January 14, 2008, 11:37:56 PM »
Whooops, didnt read between the lines, wondered what "stats" was, now i know, :).
