Author Topic: PSP UAE4ALL r1 - Compatibility Thread  (Read 44593 times)
baboon
  • Amiga fanatic
  • Moon Monkey
« on: January 16, 2008, 07:12:25 AM »
« Last Edit: February 03, 2008, 03:32:26 PM by FOL »
john4p
  • PSPUAE Moderator
Re: RIVAL PSP AMIGA EMULATOR TO PSPUAE!
« Reply #1 on: January 16, 2008, 11:58:28 AM »
I've tested some favorites of mine:
Lotus Esprit Turbo Challenge - works great (Throttle 60): smooth gfx (but constant gfx error popping up every couple of seconds), almost perfect sound
Lotus Turbo Challenge II - doesn't load
Paradroid 90 - works very good (Throttle 20!): relatively smooth gfx, almost perfect sound
Stunt Car Racer - couldn't input name: thus not working yet...
Turrican - works great! (Throttle 40!): relatively smooth gfx, good sound (you can't use grenades since you can't push ALT...)
Turrican II - works good (Throttle 40): gfx relatively smooth when alone ;), choppy with enemies, good sound
Turrican 3 - Intro and Menu working with great sound, but game doesn't load
Biggest problems at the moment is that the gfx are only horizontally stretched and the control can't be configured (and no keyboard input).
When gfx and control are configurable it will be a tough competitor for PSPUAE...
Note that the second joystick-button is emulated (circle button), so you can use the powerlines and the gyroscope in Turrican I+II.
The first joystick button is awkwardly placed on triangle and the joystick is the analog stick.
Very nice first release!
« Last Edit: January 16, 2008, 12:14:05 PM by john4p »
« Reply #2 on: January 16, 2008, 12:47:43 PM »
ok i try whit Throttle 0 and frame skip 1, and Fire & Ice run second time good whit good speed and sound..
run also
Arcanoid
Gods
Bubble bobble
Mr.Do run
Xenon2
some of that game run fine (with the second effort) . dunno..
we hope in a future collaboration whit PSPUAE..
« Last Edit: January 16, 2008, 01:13:45 PM by Anemos »
john4p
  • PSPUAE Moderator
Re: PSP UAE4ALL r1 - Alternative PSP Amiga Emu
« Reply #3 on: January 16, 2008, 03:25:51 PM »
... actually this seems to be a result of the throttle - which is probably just a fancy name for CPU-Chipset ratio is it not?
Seemed so to me, too.
Some more tests:
Hybris - works okay (Throttle 60): relatively smooth gfx (top and border missing), good sound
Lost Patrol, The - doesn't load
Lotus III - doesn't load
Stunt Car Racer: The New Tracks - works great (Throttle 0!): almost full speed gfx (but unfortunately only horizontally stretched, but not vertically), almost perfect sound
Note you can push the fire button to proceed instead of <Enter> in "Stunt Car Racer: The New Tracks" when prompted to enter your name. Thus this game is already playable. Be aware that it's difficult to find an ADF of TNT (you have to google pretty hard... ;)).
« Last Edit: January 16, 2008, 05:04:00 PM by john4p »
PSPrulez
« Reply #4 on: January 16, 2008, 06:41:53 PM »
'Creatures' runs very well! Always loved that game. Now i can play it proberly because on pspuae it didn't.
This is an emulator that you should really check out.  :)
« Reply #5 on: January 16, 2008, 07:00:27 PM »
Ok, I do not post here very often it seems - I am more of an interested reader at the moment, but I want to make a statement here:
DO work together. This is -the- chance to finally create the near perfect portable Amiga.
Some already said it and I just want to make it clear that there should be no competition here and I know that a serious developer sees fellow coders working on similar projects as a fine oppurtunity to improve - for both ;) Im looking forward to a combination of the amazing compatibility of PSPUAE and the fluid sound of UAE4ALL. Well I do know that the coders of PSPUAE would get this right, I just hope the coders of the other project will see the possibilities, too ;)
Interesting times ahead :)
Never have seen it as a competition, and never will. As I said its great there's another emu to choose from. I was debating changing the original thread title, but horace decided for me, ;).
delta191
« Reply #6 on: January 17, 2008, 11:03:20 AM »
« Last Edit: January 17, 2008, 03:07:36 PM by delta191 »
speedvicio
« Reply #7 on: January 17, 2008, 03:09:01 PM »
Insert the decompressed rom or GZip compressed format
Force throttle from 0 to 40 (better 20)
If you have a black screen try to force Super Throttle R and after L
I have tried more game:
Super Frog run - Almost Perfect
Turrican - Almost Perfect
Wiz'n Liz - Playable
Apidya - Playable
BC Kid - Almost Perfect
Lotus II - Unplayable
Jim  Power - Slowed
Fire and Ice - Playable
Ruff'n Tumble - Almost Perfect
Exscuse for my bad english
« Last Edit: January 17, 2008, 07:54:11 PM by speedvicio »
« Reply #8 on: January 17, 2008, 03:11:25 PM »
Yes, you must make sure you are using the overdumped (512k) Kickstart 1.3 rom with UAE4ALL - i have heard the same said of the GP2X version.
the "genuine" kickstart rom is only 256kb big, and works fine with PSPUAE however. This will be becuuse E-UAE is a more universal version of UAE.
this would be  a likely cause of  anyones problems if you cannot get the emulator to go beyond the menu (i had the same initially) - i dont know why this is not in the Readme file frankly.
« Last Edit: January 17, 2008, 03:13:34 PM by Hungry Horace »
john4p
  • PSPUAE Moderator
« Reply #9 on: January 21, 2008, 08:55:09 AM »
Apart from the games that require keyboard input the compatibility on this emu so far is fantastic for a R1 beta release.
Unfortunately it doesn't seem very stable:
Turrican crashed at the boss of level 2-2
Lotus I always crashes after a couple of races
Paradroid 90 always crashes after a couple of droid-conquering-games
(haven't intensely tested other games so far)
delta191
« Reply #10 on: January 21, 2008, 08:28:54 PM »
delta191
« Reply #11 on: January 22, 2008, 08:57:03 PM »
All tests with 0 throttle - 0-1 or 2 frameskipping.
xybots - yes works well
Gods - perfect
backlash - perfect
pacmania - works fairly well, tad slow.
Dungeon master- yes works well - arkward mouse/direction buttons control.
Xenon II - runs lovely
Xenon - works well, bit slow in places. dont forget to waggle joystick left and right to switch ship mode.
platoon - works well.
better dead than alien - nice space invaders clone. working well.
rtype II - works well until you progress into game, slows down dramatically.
rtype - near ferfect speed - 1 frameskip - no throttle. nice.
rampage - needs keyboard.
revenge of defender - works really well.
road rash 2 - needs keyboard.
barbarian (palace) - needs keyboard.
renegade - works ok. frameskip 2 no throttle.
mega pheonix - works ok witout frameskip. to fast with frameskip.
menace - works to menu, then needs keyboard to start.
ninja mission - loads ok but crashes once in game.
operation wolf - works ok but needs analogue support for mouse control.
wings of fury - works well.
silkworm - works well.
f29 - retaliator - gets to menu ok, then needs keyboard.
jungle strike - works well without frameskip or throttle but you cant change weapons, needs keyboard.
Swiv - works good speed, slight graphic garble on scores.
Leaderboard (golf) - yes working fine.
Kamikaze - works to menu, then needs 1 -2 on keyboard.
Klax - runs ok but with control issues.
sidewinder 2 - works well, no major issues.
escape from the planet of the robot mosters - dies whilst loading.
exile - works well.
exolon - works ok, but it's a naff game!
eagles riders - needs space bar for disk2.
1943 - works well.
sidewinder - loads ok to intro but can't start, needs keyboard to start.
starglider - loads ok, then needs E on keyboard.
alien 3 - works well frameskip 1 no throttle, needs keyboard to change weapons.
alien syndrome - works ok to menu, needs f10 key to start.
another world - works flawlessly, tried up to meeting alien in cage on disk2.
arkanoid II revenge of doh - near perfect with frameskip 1, no throttle.
golden axe - working nice frameskip 1 throttle 0
golrunner - havn't got this past menu on my version.
godrunner II - runs well until you need space bar for scenery disk.
speedball 2 - crashes psp upon loading screen.
total carnage - works well, slight graphic background flicker. good game.
cannon fodder - works good. bit tricky with direction buttons for mouse.
barbarian II psygnosis - works good.
cabaret asteroids - loads fine, but needs 1 or 2 on keyboard to start.
captive - seems to work good, but direction buttons for mouse, spoils control.
chaos engine - crashes and shutsdown psp.
cabal - loads ok but then needs f1 or f2 keyboard to start.
chuckie egg II - works ok, tuff game though.
city defence - loads ok, but then needs 1 or 2 keyboard to start game. (its missile command arcade clone)
commando - loads to title screen, then locks and powers off psp.
flying shark - works well, frameskip 1, throttle 1.
flashback - works well, until you need to use keyboard to draw your weapon!
chessmaster 2000 - works great.
chesssmaster 2100 - works ok but needs "press return key"
classic invaders - works but with graphical errors.
colossus X chess - working, no problem.
croak - works ok, bit jerky.
croak 2 - works ok, bit jerky.
missile command V2 - loads ok then requires 1 or 2 on keyboard.
P.O.W - works well but direction buttons are rubbish to control mouse movement.
prince of persia  - perfect.
plutos - loads fine but then requires 1 or 2 button to start game.
sensible golf - plays well. good golf game.
perfect - means near perfect! lol, seriously - it plays smoothly enough to be very enjoyable and the sound is very good.  :) I should know, i test lots of games/emulators on psp.  :)
I dont use the throttle - it seems to cause to many graphical issues or random crashes.
will update with more!
The Evolution Of Life
Re: PSP UAE4ALL r1 - Compatibility Thread
« Reply #12 on: February 04, 2008, 05:24:41 PM »
Captain Planet - Way too slow, sometimes doesn't work, when it does the picture and sound are slow and choppy.
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
« Reply #13 on: February 04, 2008, 05:35:14 PM »
lol, you too, *FOL breaks into song* "Captain Planet, hes a hero, gonna take polution down to" ermmmm, I never watched it as a kid honest gov, ;).
Well the good news is, what im working on (PSPUAE), Captain Planet is actually running with frameskip, but still just unplayble (still its a start, running at around 5 to 8 with Auto Frameskip). However Robocop is now playble rather decent, as are a few others, and thats not even using chipset options.
I got my head stuck right into the code, and am currently trying lots of different ideas. I just never know when to quit, have gone back over stuff, i had tried before, this time with a better understanding.
Thats the problem with uae4all, it needs a FPS counter, as its hard to judge if its perfect or not. People thinking its perfect isnt good enough. Bubble Bobble with my latest test build of PSPUAE runs with cpu max at 44 to 50 FPS with no frameskip. If I turn off FPS counter, its then hard to say it isnt perfect as it were. I know it isnt though as FPS counter tells me it not, :).
« Last Edit: February 04, 2008, 05:38:36 PM by FOL »
« Reply #14 on: February 04, 2008, 05:48:42 PM »
I kind of prefer PSPUAE, even though the sound is not to the full power of the PSP, atleast many more games work. And RISS is the s**t too.
« Last Edit: February 04, 2008, 05:53:28 PM by FOL »
3.90M33 PSP Phat
0.63 PSPUAE
No Loaders Just CFW
