Pages: [1] 2 3   Go Down
Author Topic: OPTIONS MENU  (Read 22908 times)
lionclaw
OPTIONS MENU
« on: January 28, 2008, 08:14:40 PM »
I have a PSP with custom firmware 3.80 M33. I've installed pspuae-slim in the game drawer of my PSP and it starts well, but if i press select for the options menu nothing happens :( I don't get the options menu. does anyone know whats wrong?
Re: OPTIONS MENU
« Reply #1 on: January 28, 2008, 08:55:11 PM »
Do you have any plugins running in recovery?
Re: OPTIONS MENU
« Reply #2 on: January 28, 2008, 08:56:10 PM »
it running well on Slim whit 3.71m33 ,dunno for now on 3.80M33.. maybe tomorrow i ask some main friends and ill tell you
lionclaw
Re: OPTIONS MENU
« Reply #3 on: January 28, 2008, 09:07:08 PM »
Nop, there is no plugin.
Re: OPTIONS MENU
« Reply #4 on: January 28, 2008, 10:34:40 PM »
Whats your kernel set to?
Also, if you have config1 in your configs folder try removing that
Re: OPTIONS MENU
« Reply #5 on: January 29, 2008, 12:28:34 PM »
two of my forum users, say it run fine on Slim & 3.80M33, and faster to 3.71M33  ;)
« Last Edit: January 29, 2008, 12:30:32 PM by Anemos »
lionclaw
Re: OPTIONS MENU
« Reply #6 on: January 29, 2008, 04:48:33 PM »
Where can i see whats my kernel set to?
I have no config file installed.
Is it possible that it desn't works because i've installt the slim version on a normal PSP? But the birthday version with the two folders didn't work at all.
Re: OPTIONS MENU
« Reply #7 on: January 29, 2008, 04:53:36 PM »
Sorry misread your post.
Its not a problem, slim version is phat version, just packaged to make it simple to setup on slim.
Have you got the KickStart.rom? file which is needed to use the emulator.
lionclaw
Re: OPTIONS MENU
« Reply #8 on: January 29, 2008, 07:14:55 PM »
It desn't matter if the kernel is set to 1.50 or 3.80.
I got a 3.1 rom, i just named it kick13.rom that the emulater starts up. I see the diskdrive and the animated disk. But if i press select nothing happens. If i press R+L+select the screen gets small, as it has to be.
Re: OPTIONS MENU
« Reply #9 on: January 29, 2008, 07:31:36 PM »
Ah, you need Kick1.3, thats why its crashing. As it defaults to AutoZoom, it crashes with Kick3.1 (named as 1.3). If you use kick1.3, then it will work fine. Thats why I told it to check on reset, but as your not resetting it will crash.
lionclaw
Re: OPTIONS MENU
« Reply #10 on: January 29, 2008, 08:03:33 PM »
i've tried a 1.3 kickrom but it dosen't work too. It does NOT crash. I just can't open the optins menu by pressing select. I can zoom, i can change the frameskip and so on, but i just cant open the optins menu, so i cant insert a disk file :(
Is there an other way to insert and change disk-files?
« Last Edit: January 29, 2008, 08:12:37 PM by lionclaw »
Re: OPTIONS MENU
« Reply #11 on: January 29, 2008, 08:20:02 PM »
No, note sure whats going on there. What kickroms are you using, are they Oversized? like the Amiga Forever Kickroms?
You definately dont have any config files in the PSPUAE/CONFIGS/ folder?
As Anemos reported, he has members at his site using the same files and all working fine.
lionclaw
Re: OPTIONS MENU
« Reply #12 on: January 29, 2008, 08:29:24 PM »
My rom file 512kB and sould be my A4000T Kickrom.
I've deleted the config folder and created it new, so that ther souldn't be any setings anymore, but i still can't open the options :(
Re: OPTIONS MENU
« Reply #13 on: January 29, 2008, 08:38:37 PM »
Right your completely loosing me. you have an A4000T, which contains a Kickstart 1.3? You need the A500, Kickstart 1.3
lionclaw
Re: OPTIONS MENU
« Reply #14 on: January 29, 2008, 08:43:42 PM »
No, i've an A4000T kick rom 3.1 and i've tried an 1.3 kick rom i got from the internet but all are 512 kB and none of them chrashes, i just can't open the options ether on 3.1 or 1.3.
I just want to insert a disk file, is there an other way to do so?
Pages: [1] 2 3   Go Up
