Pages: 1 [2] 3   Go Down
Author Topic: OPTIONS MENU  (Read 22910 times)
Re: OPTIONS MENU
« Reply #15 on: January 29, 2008, 08:46:56 PM »
No, i've an A4000T kick rom 3.1 and i've tried an 1.3 kick rom i got from the internet but all are 512 kB and none of them chrashes, i just can't open the options ether on 3.1 or 1.3.
I just want to insert a disk file, is there an other way to do so?
No, but I have sent you a PM.
EDIT:- Another you could try is deleting the pics from the GUI folder.
« Last Edit: January 29, 2008, 08:50:02 PM by FOL »
lionclaw
Re: OPTIONS MENU
« Reply #16 on: January 30, 2008, 04:16:07 PM »
I've tried your PM but i still can't open the menu and to delete all gui gfx didn't help too :(
Well it doesn't have anything to do with the kickrom.
Can pspuea autostart a config file?
« Last Edit: January 30, 2008, 04:53:47 PM by FOL »
Re: OPTIONS MENU
« Reply #17 on: January 30, 2008, 04:53:25 PM »
Yes, it can.
Having a 1.options file in the CONFIGS folder will override PSPUAE's default config.
« Last Edit: January 30, 2008, 04:58:28 PM by FOL »
lionclaw
Re: OPTIONS MENU
« Reply #18 on: January 30, 2008, 06:01:27 PM »
 ::) do you have an exampel config file with an .adf and r.i.s.s. for me?
Re: OPTIONS MENU
« Reply #19 on: January 30, 2008, 06:20:02 PM »
Check your Emails, I just sent you an email to the email addy, you used to register here.
lionclaw
Re: OPTIONS MENU
« Reply #20 on: January 30, 2008, 07:09:07 PM »
I've formated the memorystik but uae didn't work.
And i've with your uae the same problem as with mine  ???
Could you send me just a config file?
Re: OPTIONS MENU
« Reply #21 on: January 30, 2008, 07:10:27 PM »
Well if it aint working with my uae, then its deffo not PSPUAE causing problem or config files.
Have altered anything in recovery mode?
I dont use a config file.
« Last Edit: January 30, 2008, 07:12:42 PM by FOL »
lionclaw
Re: OPTIONS MENU
« Reply #22 on: January 30, 2008, 07:24:43 PM »
I've activatad the wma und flash support and i've turnet of the vma menu. First i thought it could be the vma menu.
How do i use the controll&options guide here in the forom to create my own config file?
Re: OPTIONS MENU
« Reply #23 on: January 30, 2008, 08:03:03 PM »
You cant, what config you trying to get?
lionclaw
Re: OPTIONS MENU
« Reply #24 on: January 30, 2008, 08:12:46 PM »
I want to try to start an .adf or r.i.s.s file directly after starting uae, so that i don't need to enter the options menu. Maybe i can use uae on this way.
Re: OPTIONS MENU
« Reply #25 on: January 30, 2008, 08:29:33 PM »
Thats simple, download any state (R.I.S.S.) from downloads section, then rename config file to 1.options, when you load it should override. the only problem is though, you need the menu, to load state, :(.
lionclaw
Re: OPTIONS MENU
« Reply #26 on: February 01, 2008, 04:46:48 PM »
uae doesn't load the 1.options by starting up :-[
I think i give up and use uae4all. It's not as good as this uae  :'( but it works with .adf filses.
Re: OPTIONS MENU
« Reply #27 on: February 01, 2008, 05:20:36 PM »
Never had anyone have this problem before, must be your end, :(. Try renaming the other option files to pspuae1.options, and try them 1 at a time.
Also, i notice on your profile (next to your posts), it says tiff loader? Are you using tiff eloader to run it?
lionclaw
Re: OPTIONS MENU
« Reply #28 on: February 02, 2008, 08:58:08 PM »
I didn't exactly know what was meant with this, and i used the tiff eloader to downgrate the firmware, so i've chosen tiff eloader. But now i don't need the tiff eloader anymore because i've customfirmware 3.80 M33-5.
Re: OPTIONS MENU
« Reply #29 on: February 02, 2008, 09:32:46 PM »
Have you updated to 3.90 M33 yet?
PSPUAE works fine with 3.90 M33 and 3.80 for me anyway.
Pages: 1 [2] 3   Go Up
