Pages: 1 2 [3]   Go Down
Author Topic: OPTIONS MENU  (Read 22909 times)
lionclaw
Re: OPTIONS MENU
« Reply #30 on: February 04, 2008, 06:38:28 PM »
Well, i think i've found the error. The home button is defect and doesn't turn 100% off  :'(
I've to buy a new volume&home panel now.
Re: OPTIONS MENU
« Reply #31 on: February 04, 2008, 06:48:57 PM »
Lmao, I thought it was an odd problem, :).
Dont buy a new faceplate / buttons, simply get an old tooth brush and clean the dirt buildup, in the gaps from the buttons .
I see problems like this alot in my job, cleaning as I said normally solves the problem. If it doesnt, then might need to be taken apart and cleaned.
lionclaw
Re: OPTIONS MENU
« Reply #32 on: February 13, 2008, 05:49:50 PM »
It looked more like shortcircuit and an other button/switch wasn't well too.
I finally got my new switches and everything works fine now.
Thanks for the help!
Pages: 1 2 [3]   Go Up
