Author Topic: PSPUAE won't start (Error 80020148)  (Read 14533 times)
guts_berserker
« on: March 01, 2008, 01:08:06 PM »
Hi
I'm new to this PSPUAE thing, so please bear with me. So I get the error message 80020148 with PSPUAE 0.63 and 0.7 when I want to start either.
I did install the software like it is written on the readme file.
My PSP has the 3.90 M33 firmware on it.
Please help  :-[
Re: PSPUAE won't start (Error 80020148)
« Reply #1 on: March 01, 2008, 01:16:08 PM »
still sounds like you've installed it wrong.
if you are using a Fat PSP, put the PSPUAE/ folder with the 1.00 eboot into:   MS0:/PSP/GAME150/
i think if its slim it just goes in MS0:/PSP/GAME/ - but since i dont have one, i dont know.
« Reply #2 on: March 01, 2008, 01:27:19 PM »
maybe he need also settings of recovery to play 1.50 kernel ?
dunno for 3.90M33-2 , i have 3.52M33 for now..
guts_berserker
« Reply #3 on: March 01, 2008, 01:31:48 PM »
Thanks, it works now! I thought 1.00 was only for Slim PSP...silly me.
« Reply #4 on: March 01, 2008, 01:43:57 PM »
hehe, :), its all working now so no problems, ;)
humanfly
« Reply #5 on: April 30, 2008, 03:25:33 PM »
I`m having the same problem with fat 3.71 m33-4 , the error is always `Game could not be started - 80020148`.
I tried with copying it to GAME, GAME150 and setting kernel to both 1.50 and 3.71, none of the combinations work :( please someone, help
« Reply #6 on: April 30, 2008, 05:59:57 PM »
Do you have everything in the correct place, you havent given much info.
humanfly
« Reply #7 on: April 30, 2008, 07:53:49 PM »
well I tried with copying both folders (%_SCE and _SCE) to:
PSP\GAME and PSP\GAME150 and with kernel set to 1.50 I get error 80020148
when I set kernel to 3.71 and copy folders to PSP\GAME the error is 8002014C, and when I copy them to PSP\GAME150 it is 80020148 again.
it`s the same with both 0.71 and 0.63 pspuae. my firmware is 3.71 m33-4. ask if you need any more info? I guess this is a noob problem but I really cant solve it? thanks for help
« Reply #8 on: April 30, 2008, 09:33:51 PM »
Those are your error codes.
80020148 = PRX type unsupported
8002014c = illegalLoadExe cfilename
From this im guessing your using Plugins?
If so disable them. As thats the only thing it can be.
humanfly
« Reply #9 on: April 30, 2008, 10:20:01 PM »
I just got it to work.. I copied the emulator from CFW_SLIM folder, I thought thats only for slim psps and it works! :)
« Reply #10 on: April 30, 2008, 10:55:42 PM »
Its in the readme, ;). Thats why I named it CFW <------ For Custom Firmware & SLIM <--------- Works with slim.
The 1.50 eboot is purely for 1.50 Firmware, if you had the 1.50 Plugin for 3.71, then the 1.50 version would work.
