<snip> <snip>
Almost,
. Your confusing yourself, I never mentioned I use 1.00 Firmware. I use 3.90-M33-2, and I never use my GAME150 folder, i dont even have the 1.50 addon installed.
When i mention 1.00, im talking about the Eboot (app/emu, in this case PSPUAE). Its been compiled to run on 1.00 (but it will work on any firmware except 1.50 Firmware). Truth be told, I dont even know if the 1.00 Eboot will work with the 1.00 Firmware (I already mention this in the readme).
So, in the case of PSPUAE, you can use the 100_CFW_SLIM 1. Simply throw the pspuae folder in your GAME folder, saves having 2 folders and the error messages will work.
Ill PM you my revised Readme, hopefully my changes will make it clear, hard to explain here through posts.
EDIT:- Think I see what you mean by multiboot, so the answer is YES, you can use 1.00, 2.xx & 3.xx Eboots in the GAME and GAME371 folder and 1.50 Eboots in the GAME150 folder.
Yes, the 1.50 addon was not required for 3.50 (or 3.60) OE/M33 and earlier versions... however with 3.71M33 and later versions, DArk Alex said he couldn't merge the 1.50 or something and it came later as an addon...
Interesting.. you say PSPUAE won't work on 1.50 CFW... when I have been running 0.63EB and 0.70 on my 1.50CFW.
lol, nooooooooooo, forget 1.50 addon, throw it away, pretend it doesnt exist. I know all that about the addon, wether it was already in the update or seperate makes no difference,
I never said it didnt work with 1.50, the 1.50 version is just the 1.00 version modified and split to use an exploit in firmware 1.50 (hence you have 2 folders for 1.50 apps/emu's).
