Author Topic: Cheap CF 44 adapter HD led active (on Amiga A1200)  (Read 5999 times)
« on: March 23, 2008, 06:37:33 PM »
As we know cheap adapters on Internet and e-bay about 1,50 euro have a problem whit HDD led
Here is the solution!
Just connect the one side of diode led to point  that shows the photo
(the first adapter on the left i have destroy the original led , and I replaced with main other different but working fine..)
In Action! youtube video :>>  http://www.youtube.com/watch?v=qhlLA_E3oN0
Cheap CF 44 adapter HHD led active (moding by Anemos)
Re: Cheap CF 44 adapter HD led active (on Amiga A1200)
« Reply #1 on: March 23, 2008, 08:57:30 PM »
he heh, thats the 1 i got, :).
Why the led mod? it comes with a led onboard.
oi, you voided the warraty, lol. Dont be sending back to me for a refund if you break it, ;).
Anemos, be careful with messing with the CF Adapter, cause I was messing with mine electrically and it fried my CF card, :(.
« Last Edit: March 23, 2008, 09:00:23 PM by FOL »
« Reply #2 on: March 24, 2008, 06:11:20 AM »
lol FOL your adapter working fine at start whit a led, because it deferent whit female socket,and more expensive  ;).
that from photo it another type ,more cheaper and has male socket used 2.5" cable to connect..
i use that to my second A1200 !  ;D
« Last Edit: March 24, 2008, 06:14:23 AM by Anemos »
« Reply #3 on: March 24, 2008, 05:57:26 PM »
Not true, mine was a female socket, I then made it male, as I had an old scrap hd connecter in work, ;). Led still worked fine, :). Led only stopped working after I inserted my 4GB PSP MicroDrive, which worked for 3 hours then fried same as my CF, :(.
Second A1200, someone is getting posh, ;).
