Author Topic: Resets after "Our Past. Our Future" screen  (Read 4902 times)
davejef
« on: May 05, 2008, 07:07:21 PM »
I have installed this on my 3.53 m33 psp but when I run it it displays a screen with the message  "Our Past. Our Future" but after that the PSP switches itself off. Is 3.53 m33 supported? Has anyone come across this before?
I believe I have installed it correctly and have the kick13.rom in the right directory.
Hope someone can help,
Dave
Re: Resets after "Our Past. Our Future" screen
« Reply #1 on: May 05, 2008, 07:18:23 PM »
Dave
Thats a kickrom missing problem, which version you using? CFW_SLIM or 1.50?
Also disable all plugins in recovery.
Is your kernel set to 3.53?
« Last Edit: May 05, 2008, 07:24:14 PM by FOL »
davejef
« Reply #2 on: May 05, 2008, 08:13:28 PM »
I am using the 1.50 version.
I have replaced the kick13.rom with another version. It now works.
Thanks for your quick reply.
Dave
« Reply #3 on: May 05, 2008, 09:02:02 PM »
Dave
Good good, :).
