Author Topic: CONFUSION: readme.txt on naming roms  (Read 5353 times)
andrewwan1980
« on: May 21, 2008, 05:32:01 PM »
Ah crap... I just realised something... regarding your Readme.txt file, this bit:
They should be named as follows:-
KickStart 1.0 = kick10.rom (A1000)
KickStart 1.1 = kick11.rom (A1000)
KickStart 1.2 = kick12.rom (A500 - A1000)
KickStart 1.3 = kick13.rom (A500 - A1000 - A2000 - CDTV)
KickStart 2.0 = kick20.rom (A3000)
KickStart 2.04 = kick204.rom (A500+ - A3000)
KickStart 2.05 = kick205.rom (A600HD)
KickStart 3.0 = kick30.rom (A1200 - A4000)
KickStart 3.1 = kick31.rom (A1200 - A4000 - CD32)
Do you mean we rename with the brackets included? So the filename is "kick13.rom (A500 - A1000 - A2000 - CDTV)" without the quotes but the letters within the quotes?
Re: CONFUSION: readme.txt on naming roms
« Reply #1 on: May 21, 2008, 05:52:06 PM »
Nope, just kick13.rom, kick20.rom etc etc.
I will revise this again with next release to make it clear.
