Author Topic: PSPUAE V0.52 Source  (Read 8439 times)
PSPUAE V0.52 Source
« on: July 21, 2006, 05:46:44 PM »
I have uploaded the source for download now.
Its in the downloads section.
Thanks Ric for releasing your updated source to us.
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE V0.52 Source
« Reply #1 on: July 21, 2006, 06:08:54 PM »
Sure you uploaded the correct file?
Looks like the 0.52 update to me.
« Reply #2 on: July 21, 2006, 06:11:11 PM »
Doubt it considering its like 6 Megs, ;), and I downloaded it to test it. Ill give you a clue, scroll down, ;)
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #3 on: July 21, 2006, 06:15:21 PM »
I'm clicking on the 0.52 Source link but all i'm getting is the 1.12 meg update.
« Reply #4 on: July 21, 2006, 06:19:03 PM »
you need to empty your Browsers cache then, cause I just downloaded again, perfect.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #5 on: July 21, 2006, 06:22:36 PM »
Ah, that solved the problem.
Ta.
