Author Topic: Game Compatability DataBase Reviewer  (Read 17886 times)
Re: Game Compatability DataBase Reviewer
« Reply #15 on: June 12, 2008, 10:02:17 AM »
Yes boss, all is well.
When I look at a game's details, publisher is mis-spelt.
When I edit a game with a reviews already in I have to re-enter all the reviews into the input frames otherwise they get cut off. This means that if someone else edits any of the details, the person who originally wrote the review has to re-enter the whole review! Try it with flashback if you like, I've saved the review on my computer so I can fix it later.
Also, when editing an entry, I have to select its 'alphabet category' every time otherwise it will default to cd32 when I save.
Everything else seems to load correctly and save correctly, but I really need these issues sorted before I continue with the rest of the reviews.
Good job though on the whole GCDB, its very useful, very easy to use and is relatively easy to add/edit entries. HOORAY FOR FOL!
Spelling, didnt notice, thanks for that, I will correct.
Yeh, I had a problem, upped the characters in the DB, but it still cut off, so I made 3 paragraphs. Simply enter each paragraph into each of the 3 text input fields and its cool. Will have to look into retifying this.
EDIT:- Oh my, I never had this problem. I did just test with IE7, you using IE7? As at home I use FireFox. In work we are forced to use IE as all the manufacturers dont support FireFox, :(. Shame on SONY.
Alphabetical cat, this should be easy to solve.
Its harder testing stuff yourself. Glad you found these issues., :).
« Last Edit: June 12, 2008, 10:05:42 AM by FOL »
« Reply #16 on: June 12, 2008, 12:18:46 PM »
I'm using firefox. What are you saving the data in?
php+database? Let me know and ill ask my coding friend or ill search for an answer via google.
delta191
« Reply #17 on: June 12, 2008, 12:35:39 PM »
skateblind I uploaed a new Another world (RISS) video today, it shows that you need to load the riss twice on pspuae 0.70b, this can be seen at start of video, the red guru screen appears at the copyright screen.
I'll add videos as you do each review, seems to make sense, maybe include a link underneath review.
its here:
http://www.youtube.com/watch?v=X2wt0ThytcU
« Reply #18 on: June 12, 2008, 01:31:11 PM »
I shall do that if FOL is cool with it, which I am sure he will be. Hopefully FOL won't mind using the actual video on the page, but still have it hosted by Youtube. What do you say FOL?
Good job with the video, maybe a few flash cards could improve it or some text edited in, like horaces SWOS RISS video, that way people know what the video is about no matter where they see it.
Keep 'em coming!  :)
delta191
« Reply #19 on: June 12, 2008, 01:40:31 PM »
I was going to hold a piece of paper, saying "Now it has Crashed.....Bummer....Blame FOL  :o
"Now try loading it Again....It works!.....Thank Horace  :D
but then I'd get shot off FOL! lol
And I certainly havn't got the front to start telling people what to do, I'm just havn't got Richard Burtons voice!
LOL ;)
« Reply #20 on: June 12, 2008, 04:45:05 PM »
you'd be better off using on-screen text like my Horace videos
http://www.youtube.com/watch?v=SmghKMqolBI
rather than flashcards.
