Pages: [1] 2 3 ... 6   Go Down
Author Topic: Help Creating RISS  (Read 61259 times)
JJXB
Help Creating RISS
« on: July 13, 2008, 04:24:46 AM »
I followed the Guide HH gave in the post linked to in the FAQ but it's not going right at all. Once i've made my disc bootable and put all of the files on it, including the edited startup-sequence it doesn't even autoextract into ram. all it does is boot to the AmigaDOS CLI. Then to get lha running i need to put mathieeedoubbas.library in a Libs folder on the disc as well. why is this not working at all?
delta191
Re: Help Creating RISS
« Reply #1 on: July 13, 2008, 07:40:03 AM »
what version of pspuae are you trying it on? I'd give it a blast on 0.63 if you havn't already done so.
You need Horace to guide you and check what your doing, he's your man! sure he will help.  :)
« Reply #2 on: July 13, 2008, 08:57:13 AM »
Your doing something wrong.
Post your startup sequence or adf file here, so we can take a look at it.
adf would proberly be better as we can see the whole picture. If your adf contains any files of a senetive nature remove them first.
You can attach files, by clicking "advanced options" on the reply screen.
« Last Edit: July 13, 2008, 01:16:14 PM by FOL »
« Reply #3 on: July 13, 2008, 12:31:56 PM »
agreed, please attach your adf and i'll let you know what's been missed ;)
JJXB
« Reply #4 on: July 13, 2008, 04:27:12 PM »
I managed to solve the problem with the Startup-Sequence (forgot the S folder) but now i have another problem. now the assign command isn't finding RAM:. It doesn't have any lha file on it yet since i want to make it a template disc as it were.
« Reply #5 on: July 13, 2008, 04:31:54 PM »
How you trying assign?
assign PROGNAME: RAM:?
If I remember correctly, you need to assign T: to RAM:
Would need to see your startup-sequence.
JJXB
« Reply #6 on: July 13, 2008, 04:42:35 PM »
my disk is attached to the previous posts.
« Reply #7 on: July 13, 2008, 05:31:01 PM »
Here you go, fixed, :).
How did you create that disk, cause I had to transfer it to a freshly created adf I made in WinUAE.
Also, there were errors appearing in the Startup-Sequence. Abit like they were edited by something (notepad) in windows.
JJXB
« Reply #8 on: July 13, 2008, 05:44:25 PM »
i don't know why you had trouble since i created the disk through winuae myself. plus i did edit the startup-sequence through my emulated amiga so i don't know why those errors were there. thanks anyway FOL :) that's a big help :)
« Reply #9 on: July 13, 2008, 06:48:22 PM »
No probs, all sorted now, :).
If your planning on doing alot of states, I can dicuss with the other site staff about making a RISS Istaller.
delta191
« Reply #10 on: July 13, 2008, 07:23:35 PM »
The birth of a new RISS creator? that would be  8)
 how we need a few of those, bit like rocking horse poo at the moment! lol ie: very RARE.
what game was the RISS created for dare i ask? (excuse my noseyness)
« Reply #11 on: July 13, 2008, 07:26:15 PM »
Xenon 2 I believe. Thought we had Xenon 2 already?
delta191
« Reply #12 on: July 13, 2008, 07:37:34 PM »
Yes - the xenon II RISS is already in downloads, runs well to.
How long does it take to create a RISS? does it take ages and is it difficult?
I've read Horaces guide but it doesnt sound easy to me! lol
If it doesn't take long to do and is easy, it begs the question......why havn't we got more?
I know horace likes more advanced amiga projects and FOL is a busy Beta! does nobody else know how to create a RISS?
« Reply #13 on: July 13, 2008, 08:14:21 PM »
i KEEP offering lots of install disks for RISS that i have already made, but no one ever seems to act very interested when i mention them?
it's not difficult to create the install disks if you understand amiga systems of working, and if you understand why what you are doing works.
Once you've done a few its easy to cut corners and produce more. (mine use the ZIPS direct from www.whdownload.com )
delta191
« Reply #14 on: July 13, 2008, 08:30:34 PM »
so how do we get from install disks to a riss Horace?
is the technical side complete in creating the install disks? (i remember you giving me some goldrunner install disks, at least i think thats what they were)
What do I need? I dont have an Amiga - do I need one? I have WinUAE 1.4.4 on my Pc but only use it for running ADF games! lol.
If you have cybernoid or cybernoid II install disks, I'll try those as a test and see if I can do it.
I have most configs for most games on pspuae if they help.
Pages: [1] 2 3 ... 6   Go Up
