please find attached Goldrunner Riss, remember its setup for running on 0.63BE.
Please remember I'll always try to setup games to run with good sound\decent speed balance and ease of play! some can be made to run faster but at the expense of bad sound and to difficult to play.
I check the running of a game on winuae to see how fast it should be running, well to get a good idea how it should look!
If its upto scratch FOL, add it to the RISS downloads section.
Remember, its horaces work, I couldn't do a RISS without his install disks! without Horace I'm lost
All i can do is try and make it run with FOL's Emulator best I can
lol.
I've also included a link below for screenshot for your download section and the readme contents if you need it
http://img2.freeimagehosting.net/image.php?b983be946e.jpgGoldrunner is a rather good vertical scrolling shoot em up, with a catchy chip tune by Rob Hubbard.
controls:
psp start= start game
psp square= fire
psp circle= Boost/thrust
psp left shoulder= SFX only
psp right shoulder= enable music
psp cross= return (skip name entry) on hi score table entry.
psp triangle= Activate keyboard display.
