Author Topic: HDD File support in PSPUAE?  (Read 10984 times)
spell2000
« on: August 17, 2008, 10:26:46 AM »
is there a way to add HDD-file support for the next PSPUAE release?
this is my biggest wish!!!!!!!!! ;D ;D ;D
thx spell2000
P.S. File extensions for uae *.HDF
« Last Edit: August 17, 2008, 10:28:31 AM by spell2000 »
Re: HDD File support in PSPUAE?
« Reply #1 on: August 17, 2008, 10:31:36 AM »
thx spell2000
Not with the current source.
tsabrak
« Reply #2 on: June 05, 2010, 10:09:08 PM »
Hi.
Sorry for digging up old post, but do you still cant add HD support to PSPUAE?
It will be amazing to run good, old Workbench on PSP with games installed on HD not on FD. Maybe progs too.
Keep doing your great work. Your emulator have more value for me than Daedalus. (I grew up on Amiga 500+/1200)
Pancio
« Reply #3 on: September 09, 2010, 04:39:46 PM »
HDD support is a great idea. do you think we gain more speed using HDD images to run games instead of ADF images?
as u know F0L the company has a lot of HDD prepared games. it would be nice to use them with your amazing emulator.
« Last Edit: September 09, 2010, 04:54:48 PM by Pancio »
« Reply #4 on: September 09, 2010, 08:27:44 PM »
there is no need to use "the company"'s pre-installed (cough *actually KG's WHDs* cough) games.... if HD support happens on the PSP then i have a plan in place already to make the setup process as easy as possible.
Dreedo
« Reply #5 on: January 11, 2011, 01:12:06 PM »
As for making games faster, it probably would increase loading times, but it would take additional RAM. Although not as much RAM as the RISS we see, i recommend you try them out if you haven't already. The loading times are slightly faster and they usually run games at 100% speed, with some minor tweaking by yourself. RISS often have auto frameskip so i usually switch that too 35 or so and it makes it much better.
