Author Topic: Cannon Fodder - New Campaign  (Read 18873 times)
Re: Cannon Fodder - New Campaign
« Reply #15 on: August 27, 2008, 09:47:12 PM »
Cannon Fodder - New Campaign RISS for PSPUAE 0.72 in downloads section
« Last Edit: August 27, 2008, 09:50:58 PM by Hungry Horace »
SoczI
« Reply #16 on: August 28, 2008, 07:34:45 AM »
This RISS has an error or it's just because I'm using 0.63. Anyway the mouse is not set. It won't work until you set the analog stick to Mouse and not Joystick 0. But it works and it's great - thx Horace.
« Reply #17 on: August 28, 2008, 07:38:26 AM »
as the above -clearly- says it was made for 0.72, it's not surprising it doesnt work with 0.63!!
it uses turbo cpu setting, so i would expect a -lot- of problems with trying to run it on 0.63
you really should be using the latest version now.
delta191
« Reply #18 on: August 28, 2008, 08:01:38 AM »
why use 0.63 version now? there really isn't much reason now, 0.72 with turbo enabled gives a worth speed increase.
Although 0.63 was a good solid base, but its starting to get left behind in many departments!
you should use 0.72, its worth it for the sound fix alone, never mind the extra speed with turbo enabled.
For once, me and Horace agree on something lol  :P
« Reply #19 on: August 31, 2008, 03:38:35 PM »
http://aminet.net/package/game/data/CFNC
CFNC updated to 1.0.1 - install package linked above. I will post a pre-installed version when i have one.
