Author Topic: Grand theft auto  (Read 5136 times)
dt311077
Grand theft auto
« on: July 23, 2006, 12:07:11 PM »
I was wondering if i need grand theft auto to run psp uae?
Im sorry my posts are all over the place but have tried your
suggestions before to no avail.And i dont know what HAND
is but but the emulator seems to run and yes i can insert
the disks but nothing happens.Thanks for your time.
« Last Edit: July 23, 2006, 12:12:17 PM by dt311077 »
Re: Grand theft auto
« Reply #1 on: July 23, 2006, 12:17:45 PM »
HAND is the rom boot screen, pic ofhand holding a disk.
Yes you do need GTA-LCS, as the TIFF exploit aint compatable.
make sure yournot setting the memory to high, as its 2 Megs max for V1.50 PSP and about 1 to 1.5 Megs max for V2.+ PSP.
Also some adf`s just wont work, its not PSPUAE, but rather the E-UAE source, as E-UAE becomes more compatable then so will PSPUAE.
Oh 1 last thing, GTA has been patched to stop eloader working now, so make sure you get the right 1, I believe the 1 with the age logo on the spine is the elaoder compatable 1.
« Last Edit: July 23, 2006, 12:21:09 PM by FOL »
« Reply #2 on: October 03, 2006, 06:55:32 PM »
Solved......
