Author Topic: Why is it soooo slow???  (Read 15269 times)
osiris37
Re: Why is it soooo slow???
« Reply #15 on: October 28, 2008, 07:11:18 PM »
Wow! not the best way to start off in the forums here mrbob2! :o
i have a LOT of fave games and i just want to whack in a adf and play.
surely though if these are your 'fave' games then taking time to make sure the games you love work is definately well worth the time, rather than throw in the towel at the first hurdle and dismiss something as, and I quote, "not quite usuable at the mo". If you take you're time with PSPuae then you'll realise what great a job FOL has done with it so far, and you will also realise why some of us spend so much time using it... I buy games for my PSP all the time however PSPuae probable gets used 90% of the time over everything else... surely that say something against you're 'not quite useable' comment... anyway rant over!  :-X
As you are probably aware if you read through other threads in this forum that we are all willing to take the time to help people out. but we'd need some info, some games admittedely are sluggish, some have naff sound, we are all aware of this and that's what drives FOL on to make this a better emulator with every new release.
Now down to business, 'drops bat and adopts friendly smile' what games were you trying out? some of us have tested hundreds of games, maybe we have a config already sorted for the ones you want?   ;D
« Last Edit: October 28, 2008, 07:15:30 PM by osiris37 »
Pancio
« Reply #16 on: September 09, 2010, 06:03:03 PM »
« Last Edit: September 09, 2010, 06:18:19 PM by Pancio »
« Reply #17 on: September 09, 2010, 06:34:29 PM »
Two words.
ASM CORE.
;). Still waiting for someone to help me with the PSP's ASM Core.
Oh and the fact GP2x is open source, PSP needs to use hacks.
Pancio
« Reply #18 on: September 09, 2010, 07:17:02 PM »
so there's a hope to get things go better ;) ? do you think psp is powerfull enough to smoothly emulate amiga ?
« Reply #19 on: September 09, 2010, 09:55:20 PM »
Yes with an ASM Core, like UAE4ALL on GP2x has.
The only down side is you loose cpu's above 68K.
Pancio
« Reply #20 on: September 09, 2010, 10:17:11 PM »
so the only thing i can do is wish u good luck ;) i hope u'll find solution. cant wait for your next releases
peace
