Author Topic: Need some help please :)  (Read 6645 times)
0 Members and 5 Guests are viewing this topic.
ToonFisch
« on: January 09, 2009, 01:57:54 PM »
Hi Folks
First i have to say Thx for this Awesome Emulator!
I got a few Questions
My PSP Firmware is 5.00M33 and im running the latest PSPUAE and got 1.3Kick
So i wanted to play Pinball Fantasies it all worked but its a little bit laggy ..
So i dont got much knowledge on theses CPU things. i tryed to work out some options but still no effect
Is there a way to run it smooth?
Thx for any Replies :D
Re: Need some help please :)
« Reply #1 on: January 09, 2009, 06:18:29 PM »
Hi Folks
Unfortunately, this is 1 of those games, that it doesnt run so well. Im not sure on the settings Horace uses, as he plays this game alot.
Im sure horace can help tell what CPU settings he uses to make it playable.
ToonFisch
« Reply #2 on: January 09, 2009, 11:46:03 PM »
thx 4 reply!
Sorry do bother u but can u tell me some games that will run smooth?
« Reply #3 on: January 10, 2009, 12:50:55 AM »
actually, i rarely play this game on PSPUAE... i dont even like playing it on e-uae or winuae much either because i dont find them smooth enough either.
however, you may find it plays reasonably if you disable the sound (something that does work for Pinball Dreams)
as for the cpu config, i'm afraid i have no idea on the latest versions.... just try playing with the cpu-chipset option, although i seem to recall always using "max" speed because otherwise there is potential for too much keypress-lag.
Games that i play regularly which run great under the right settings:
Bloodwych / Entended Levels
Lemmings 1 / oh-no / 2
Mega Lo Mania
Supremacy
Rainbow Islands (surprisingly)
Hammerfist
Time-Machine
there are loads, but it really depends on what kind of games you like.
delta191
« Reply #4 on: January 10, 2009, 08:25:23 AM »
try browsing  and searching for your favorite games on the http://uk.youtube.com/pspuae site to see if
your game runs at a decent enough speed, theirs a couple of hundred videos of popular games.  :)
Also, dont forget to try turning on the turbo in 0.72, to my experience most games get a nice little boost, some games more than others, so it's worth a try.
I've never tried an amiga pinball game, must admit, maybe I should! lol :)
ToonFisch
« Reply #5 on: January 23, 2009, 02:54:02 PM »
Ok im using this emulator for 2 weeks now and its MUCH FUN i love to play Moonstone on my Bus to School *tehe*
But im encountering some problems , when im loading a certain savestate Shadow of The beast 2 for example it starts loading but then the 3.1 kickrom screen comes up and nothings happen , how can i get it running? I do got 3.1 and named it correctly and its not from Amiga Forever
« Reply #6 on: January 23, 2009, 09:43:07 PM »
All R.I.S.S.'s use KickStart 3.0, if you encounter a crash or kickscreen simply reload that state.
Also if your using 0.72 FE, then the states wont work (im working on trying to fixing this).
Check out the RISS Faq's, on main page.
« Last Edit: January 23, 2009, 09:45:57 PM by FOL »
ToonFisch
« Reply #7 on: January 24, 2009, 04:26:43 PM »
Nevermind got it working haha thx again for this emu!
« Last Edit: January 24, 2009, 10:01:38 PM by ToonFisch »
