Pages: 1 2 [3] 4   Go Down
Author Topic: wishlist  (Read 51541 times)
Feark
  • HE JUST LEFT....WITH NUTS
Re: wishlist
« Reply #30 on: August 22, 2006, 08:11:21 PM »
One thing that is missing but should be added is that adf can be deleted from the list. All the game I have tried has worked with 0.53, but it has been many testing with different adf to same game cuz some works and some doesnt, and had been great if the nonworking could be deleted directly from the EMU option so they dont take any valuable space (even if Amiga should be prioritize first) on the MS.
Just a thought :-*
Re: wishlist
« Reply #31 on: August 23, 2006, 10:11:20 AM »
Just a thought :-*
Lazy sod, ;). Do what I do, either remember or write it down, lol
cleanoff
function key
« Reply #32 on: September 14, 2006, 04:07:32 AM »
MOSTLY Harmless
I was playing Elite recently  :D , and had to work out all the keyboard commands for thrust, hyperdrive, retro, etc (there's a lot ???). Whilst bringing up the keyboard for some games is enough... it's way too difficult to use this method for a game like Elite, which needs quick key pressing :(. I know that keys can be bound for PSP buttons... but, here's my idea.
 :-\ Would it be possible to have some kind of "function" button so that once held down gives a different command, simple example: pressing the L or R shoulder buttons while holding triangle button.
 :-\ Alternatively, simple example: once up, down, left, or right on d-pad is pressed, there's a different configuration for all PSP buttons. [for just the L, R, & 4 basic buttons you could have 4 x the key binding :D, in other words 24 key-mappings rather than 6  ;D]
Although this might seem a little complicated :o and granted un-necessary for most games, for the games that do need lots of keyboard action it'll make the games very much playable... as is, besides listening to the Blue Danube for intro and crashing into space stations while trying to dock, Elite is unplayable. :(
Last thing: excellent job guys! ;D ;D PSPUAE is my most used homebrew app... how i love to play the old classics like Alien Breed, Paradroid, Escape from Colditz, and so many other absolute gems.  :D
 ;D ;D ;D keep up the great work ;D ;D ;D
Re: wishlist
« Reply #33 on: September 14, 2006, 11:10:47 AM »
you'll be pleased to know i have already suggested such a keyboard assignment possiblity, having stolen the idea from the excellent pSpectrum emulator....  so when Ric has finished adding his latest bits and pieces, perhaps he'll consider looking into it - i hope so.
Re: wishlist
« Reply #34 on: September 14, 2006, 10:40:37 PM »
Quote from: Hungry Horace
Is it on the to do list?
« Last Edit: September 15, 2006, 02:07:31 AM by Hungry Horace »
Re: wishlist
« Reply #35 on: September 15, 2006, 02:09:47 AM »
well i only spoke to you about it, and not Ric directly, so i didnt add it myself, thinking you might if the idea was confirmed as a good one.
ffs.... i editted FOL's post again. sorry.
EmuChicken
Re: wishlist
« Reply #36 on: October 11, 2006, 03:54:34 AM »
lo anyone
how about a nice stretch screen feature that fills the psp screen? :-D
Re: wishlist
« Reply #37 on: October 11, 2006, 06:02:24 AM »
lo anyone
lol, hey Emu,
ermmm you aint tried 0.55a?
Zoom feature stretches quite well. Dont think stretching will happen though, as the filter only works on PC`s, I have spend many hours playing around with the source to try and stretch the screen, all resulted in the screen getting screwed up, so I gave up.
EmuChicken
Re: wishlist
« Reply #38 on: October 10, 2006, 10:53:09 PM »
Yeah Ive just installed it, but I think it just zooms and not stretches.  I just think it'd be handy as I use all my emus in stretched mode and it fits great on the psp.
Zoom works ok , until you try and look at your damage meter or whatever on supercars 2 :/
Re: wishlist
« Reply #39 on: October 10, 2006, 11:06:37 PM »
Indeed, some games can go off the screen, :(
quetz67
Re: wishlist
« Reply #40 on: January 23, 2007, 11:10:46 AM »
I tried Eye of the Beholder (doesnt work) and Eye of the Beholder 2 (works).
EOB 2 plays very good after mapping some keys (unfotunately some kkeys from the PC version dont work). What I need most would be mousestates for right clicks (fighting).
And either 4 disc drives or HDD installation (my suggestion would be to make the install on WinUAE and just read the files generated there instead of wrting new tools).
Re: wishlist
« Reply #41 on: January 23, 2007, 05:16:52 PM »
All your wishes are already a reality, ;).
Mousestates are already in the current release, and horace is working on a ram installed Eye of the Beholder, I believe.
Re: wishlist
« Reply #42 on: January 23, 2007, 06:34:34 PM »
he means RIGHT-CLICK mousestates. currently they left-click.
EOTB 1 /2 savestate will not happen. they are far too unstable even in 6 meg with the original installers.
better off waiting for HD support.
Re: wishlist
« Reply #43 on: January 23, 2007, 07:01:13 PM »
Whooops, ;), thought it had been added, ill add it to to do list, ;).
Re: wishlist
« Reply #44 on: July 06, 2007, 10:13:24 PM »
i noticed a number of guests / bots or something viewing this thread earlier, so i looked at it and was quite pleased with how many functions listed in the first post are now sorted!! top job! - i know its an archived thread, but its kinda nice to see.
i had a good chuckle when i read this though:
More memory wont happen, I had Fast 512kb andChip 1024KB and Slow 1025kb, but anything else kills it.
ye of little faith, haha
« Last Edit: July 06, 2007, 10:15:43 PM by Hungry Horace »
Pages: 1 2 [3] 4   Go Up
