Author Topic: Good Setings  (Read 4326 times)
hYdRoNiC 420x
Good Setings
« on: July 25, 2006, 02:33:03 AM »
so i was wondering what setings you would recomend for less lag i allready turned off sound and raised fps to about 2 what other setings would you recomend btw that did help a little and if it gets real laggy i kick it up a notch to 3 fps but what do yall use  :)
super_hoops1967
Re: Good Setings
« Reply #1 on: July 25, 2006, 08:33:13 AM »
for swos i turned of the auto framerate and put it to 3 that seemed to make it a little less jumpy.
Re: Good Setings
« Reply #2 on: July 25, 2006, 11:31:24 AM »
errr guys..... that's what the "compatibility database" on the front page is for.... so you can look up what settings people have used.  ::)
http://www.condor.serverpro3.com/pspuae/index.php/topic,36.0.html
