Author Topic: Weird  (Read 6282 times)
hYdRoNiC 420x
Weird
« on: July 25, 2006, 02:46:47 AM »
yes i find it weird when i look every where i can not find time setings lol i am on Central Time US time zone but i cant change it lol my time is way off on htis forum
ParaSitius
  • Swish
    • ParaSitius.com
Re: Weird
« Reply #1 on: July 25, 2006, 03:43:33 AM »
You just need to use the 'Time Offset' option that's in the 'Look and Layout' section of the Profile.  Just put in -8 to have the time set to 8 hours (or however many hours behind you are) after British Summer Time that is currently in effect over here.
Or the Auto Detect function which I've just noticed.
Then click Change Profile in the bottom right to confirm your choice.
« Last Edit: July 25, 2006, 03:46:27 AM by ParaSitius »
hYdRoNiC 420x
Re: Weird
« Reply #2 on: July 25, 2006, 05:42:47 AM »
kk i got you man ill try that out now
Edit: works perfect now thanks
« Last Edit: July 25, 2006, 05:44:24 AM by hYdRoNiC 420x »
ParaSitius
  • Swish
    • ParaSitius.com
Re: Weird
« Reply #3 on: July 25, 2006, 11:41:43 AM »
Nay probs.
