Author Topic: This is nuts!!!!  (Read 6426 times)
ParaSitius
  • Swish
    • ParaSitius.com
This is nuts!!!!
« on: July 25, 2006, 03:32:47 PM »
Just spent the last hour going through my collection of floppy's trying to find a working copy of Workbench 1.3  :-\
Do floppies have a limited life-span before they start to degrade and lose info?
ParaSitius
  • Swish
    • ParaSitius.com
Re: This is nuts!!!!
« Reply #1 on: July 25, 2006, 03:48:35 PM »
Either the copy of 1.3 I'm currently using is unstable or I've forgotten just how easy workbench can crash.
Dammit, not again.
« Reply #2 on: July 25, 2006, 04:04:21 PM »
workbench crash??
haha - not likely ;)
yes disks do degrade.... even the magnetic pull of the earth is slowly wiping them all. and that doesnt even allow for disk-quality and other factors which might cause them to die.
suggest you get a copy of ADFBlitzer and put a new copy from ADFs onto fresh / working disks.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #3 on: July 25, 2006, 04:22:44 PM »
I'm just trying to back up my two Wings disks, even the manual says I should do it.  Just having trouble with disk 1 which WB1.3 just can't seem to read when I choose the duplicate option.  I even tried using XCopy 1.3 which worked on disk 2 ok but failed on disk 1.
The Chaos Engine
  • Six Hard Nailed Mercenaries For Hire.
« Reply #4 on: July 25, 2006, 08:52:44 PM »
i had more problems with 3,5 disks with my mac+ and a500 than those 5,25 for my c64.
I would bet 90% of those 5,25" disks still work.
Although Primitive, The Machine Became Incredibly Powerful And Turned Against Its Creator. Its Power To Corrupt Time And Matter Was Out Of Control. A Cloud Of Chaos Descended Over All The Lands. Humans And Animals Were Turned Into Ravenous Beasts. SIX HARD NAILED MERCENARIES FOR HIRE.
Hai
  • compute + compose
  • audio, video and stage artist
    • THE DUNGEON
« Reply #5 on: July 27, 2006, 10:58:10 PM »
Yeah it like the 3.5" disks are more vulnerable than 5.25". Most of my C64 disks still work while many Amiga disks have errors. DMS (was it called that?) and ADF is great security!
A1200, Blizzard 68060 (clocked to 66mhz), Melody PRO audioboard, 16mb fast, 850mb HD, SCSI cd-rom
« Reply #6 on: July 27, 2006, 11:18:23 PM »
yes it was called DMS.
and IPF (CAPS) is even more so essential for preserving disks.
although since i dont know if the IPF reading code is open source, we are unlikely to ever see it supported on pspUAE.
