Author Topic: Amiga Bloodwych Files  (Read 23200 times)
Re: Amiga Bloodwych Files
« Reply #15 on: March 19, 2018, 08:44:24 PM »
Hi, and thank you for the help. Sadly I'm unable to get it to work.
I looked in the .lha-archive and the file is named ExtendedLevels.Slave, so I changed the WHDload-arguments from Bloodwych.slave PRELOAD to ExtendedLevels.slave PRELOAD. I get an error saying "Did not find the specified WHDLoad slave...."
Any ideas?
Hmm. Normally i would say to check that it isnt case-sensitive (.Slave not .slave) , but on Windows, this is unlikely.
I will have to take a look this with FSUAE myself to work it out
Hi again, Horace.
Just wondering if you have had the opportunity to look at this issue yet.   :)
sorry, i did, but i couldnt work out why it wouldnt let me select the extended levels slave, and strangly it only shows as one 'scanned' entry in FS-UAE, is that right?
I might be able to help you fix this with a seperate WHDload booter (which i use for another project) ... I will get back to you on this (sorry about the wait)
Borgelin
« Reply #16 on: March 28, 2018, 05:24:50 PM »
no problem at all, take your time. I'm just happy I'm getting help to sort this out, so I'm very grateful to you. We haven't progressed beyond Serpent Tower yet anyway.  ;)
Borgelin
« Reply #17 on: October 17, 2019, 11:05:32 AM »
Any ideas?
Hi again, Horace.
Hi Horace,
sorry for nagging you on this, but it's been a while and I was wondering if you might have forgotten. :)
« Reply #18 on: November 12, 2019, 08:31:48 AM »
I ran into a similar issue if i recall - i will have to have a check again
