Author Topic: I dont understand...  (Read 9735 times)
ToonFisch
« on: March 20, 2010, 05:49:50 PM »
Hi , i just got my new Macbook ( Late 2009 White Unibody)
And wanted to start emulating on it. I downloaded the File provided by Horace and followed the instructions. Still i wont work. And how can i install a virtual HD into it? Mhh
Re: I dont understand...
« Reply #1 on: March 20, 2010, 07:36:59 PM »
you'll have to give us a bit more detail about what you've done, why it's not working etc, before i can properly diagnose the problem ;)
also - if you mean virtual amiga HD, it's exactly the same as WinUAE
Mr TEL
« Reply #2 on: March 18, 2011, 07:47:11 PM »
Hi toonfish
You've not given us much to go on here mate! I'll therefore assume you're a complete novice. In order to run UAE on a mac you also need to download the interface for it, which is Hi Torro from http://www.macupdate.com/app/mac/25618/hi-toro/.
IF you load that up and run it, then all should be clear (most of it anyway). This program enables you to create config files for UAE to use, eg, is it an A500, an A1200, how much RAM do you want and so on. You also need the Amiga ROMs in software form, which is the most difficult part, as they are the copyright property of Cloanto, who sell the Amiga Forever package on the PC. If you search around on the net, you may be able to find a set of them. Same goes for the workbench disks.
If you've got all that, setting up an amiga HD is simply a matter of going to the Devices tab in Hi Toro and allocating a chunk of your hard disc space as an amiga hardfile. You then run the emulator and format it like you would any amiga hard drive.
I must admit that emulating the Amiga on a mac is more difficult than on the PC as it's much less supported. I hope this can give you a start anyway. If I've told you things that you already know then forgive me!
Mr TEL
« Reply #3 on: March 18, 2011, 08:23:32 PM »
Hi toonfish
Mr TEL
He he, Im hoping he got it sorted by now, one year on, ;).
Dont mind me, its just friday night babble, :).
Mr TEL
« Reply #4 on: March 18, 2011, 08:44:07 PM »
« Reply #5 on: March 18, 2011, 08:45:27 PM »
