Author Topic: WHDload: Cybernoid - Slave Update  (Read 16250 times)
« on: April 25, 2010, 12:14:58 AM »
I've updated the WHDload slave for Cybernoid, and would appreciate some testing / feedback please, especially from CD32 users :)
New Features:
68000 Quitkey
Bugfix on weapons trainer
Skip title screen with Left Mouse Button or Fire
Save Scores for unregistered WHDLoad users
Press TAB on Menu to enable Original Cheat
Source Code to be included with WHD Package
Full Trainers (CUSTOM1=X) [combine numbers for multiple trainers]
1=Infinite Lives
2=Infinite Weapons
4=Infinite Screen Time
8=Infinite Level Time
16=Levelskip (including Outro)
CD32 Controls (CUSTOM2=1)
Menu: Blue (SFX Toggle)
Menu: Play (Show Highscores)
Menu: Forward + Rewind + Yellow = Activate Cheat
Menu: Forward + Rewind + Play = WHD Quit
Game: Green for Special Weapon
Game: Forward for Cycle Special Weapon Up
Game: Rewind for Cycle Special Weapon Up
Game: Play for Pause
Game: Yellow for Quit (While Paused)
Game: Blue for Level Skip (While Paused + Cheat Enabled)
Game: Green for Level Restart (While Paused + Cheat Enabled)
Attached pre-installed version (Readme *not* updated) for your pleasure ;)
baboon
  • Amiga fanatic
  • Moon Monkey
Re: WHDload: Cybernoid - Slave Update
« Reply #1 on: April 25, 2010, 08:19:43 AM »
Nice
Although I've got a CD32 I've only ever bunt bin/cue and iso files before and haven't got a clue how to get WHDload files running on it. :(
BooBoo
  • Amiga Guru
« Reply #2 on: April 25, 2010, 05:54:35 PM »
Tested out CD32 Controls (CUSTOM2=1) on my A1200 with Commodore CD32 Pad - worked great realy makes it much nicer to play also being able to Skip the titles screen with fire.
I dont have a CD32 but could probably test under WinUae Quickstart CD32
Attached tiles from Cybernoid 2
« Last Edit: April 25, 2010, 05:58:49 PM by BooBoo »
« Reply #3 on: April 25, 2010, 07:06:49 PM »
thanks BooBoo
i'll be interested to know if it can be played on a 'vanilla' CD32 using the WHDloadCD32 version
BooBoo
  • Amiga Guru
« Reply #4 on: April 25, 2010, 08:59:11 PM »
Just testing under WinUae QuickStart CD32 seems to run fine - Do you want a quick ISO?
« Reply #5 on: April 25, 2010, 09:01:45 PM »
that sounds great BooBoo :) ISO would be good for Baboon and other CD32 testers
you were using WHDloadCD32 for that?
BooBoo
  • Amiga Guru
« Reply #6 on: April 25, 2010, 09:19:25 PM »
Yep WHLoadCD32
Zipped ISO attached
« Reply #7 on: April 25, 2010, 11:14:07 PM »
Nice
problem solved? :)
shame CD32 support is disabled on E-UAE for OSX, as it means i have to rely on others feedback :(
« Reply #8 on: April 25, 2010, 11:29:18 PM »
stupid me, i forgot i could just burn it to a CD and test on a real CD32!
just tried it... and i like!
I did however, find the 'memory resident' thing (whereby you cant reset it) to be a bit annoying, so i might look into removing that before releasing the slave.
baboon
  • Amiga fanatic
  • Moon Monkey
« Reply #9 on: April 26, 2010, 08:24:39 AM »
Nice
problem solved? :)
Yep seems all good to me. ...I used to love this game too! :) The skip title screen is ideal.
Now if only I could somehow work out how to convert the whdload of 'The Ninja Warriors' to an iso for my cd32 I'd be a happy bunny?
« Last Edit: April 26, 2010, 08:27:05 AM by baboon »
« Reply #10 on: April 26, 2010, 05:19:57 PM »
i'm sure BooBoo can give you some tips
http://www.whdload.de/games/NinjaWarriors.html
according to this, the WHD only needs 512k and there is already a 2-button joystick mode added to the slave.
« Reply #11 on: April 26, 2010, 08:59:04 PM »
BooBoo, any chance you can pop into chat and test something for me?
BooBoo
  • Amiga Guru
« Reply #12 on: April 26, 2010, 09:34:21 PM »
For the CD32 iso you need the CD32 Dev Kit
Get it here - http://www.cd32-allianz.de/entwickler/entwickler?
Use tool ISOCD
Attached Font from Cybernoid II - I ripped from ARIII screenshot while bored
« Reply #13 on: April 26, 2010, 09:38:13 PM »
attached RC2 cybernoid slave - maybe with reset-resistance removed? (guesswork)
« Reply #14 on: April 26, 2010, 10:03:31 PM »
Cybernoid II - The Revenge Slave Update
New Features:
68000 Quitkey
Bugfix on outro (no more WHD exit/Guru)
Game Over text now waits for button press
Source Code to be Included
