Author Topic: Biggest Noob ever!  (Read 8176 times)
chris2010
Biggest Noob ever!
« on: May 28, 2010, 01:03:02 PM »
Re: Biggest Noob ever!
« Reply #1 on: May 28, 2010, 01:11:57 PM »
You need a custom firmware able PSP.
whats the number on the bottom, it should be next to serial (example; PS1003).
If its really a 3000 then it can get complicated. You really need to find out which version you have, as there are different hacks for different PSP versions.
EDIT:- you could also try the patapon2 demo exploit, I uploaded a HBL version. All you need is to get the demo and save and then put the HBL download in its correct place and run it.
« Last Edit: May 28, 2010, 01:14:12 PM by FOL »
chris2010
« Reply #2 on: May 28, 2010, 01:29:08 PM »
Hi FOL!
Wow! Thanks a lot for the prompt answer and help!  :D Please excuse me if I don't understand completely what you meant as I truely am a noob
I checked the serial number as you said andit says PSP3004 (thanks now I know what I have LOL!!!)
What would be my next step to do?
EDIT: So sorry but what is patapon2 demo exploit and what is HBL version?
« Last Edit: May 28, 2010, 01:34:13 PM by chris2010 »
« Reply #3 on: May 28, 2010, 01:42:32 PM »
Hi FOL!
Will try to answer as best I can, as Im in work.
Go HERE and have a read, there is also a download link to the demo (patapon2) and save (patapon2 exploit). Once you have these, then download THIS, put it in the correct places and then the patapon2 demo, once its loaded, go to continue. Load the save (exploit) and it will load another screen. Push any key, then push right trigger. it will then load the menu. Select PSPUAE and your done.
chris2010
« Reply #4 on: May 28, 2010, 02:26:50 PM »
Again Fol thanks a lot for the fast help which is so much appreciated. I'll check this later and keep you up to date with my progress. Should every thing work perhaps I can put a little guide here for beginners like me  ;)
« Reply #5 on: May 28, 2010, 02:46:54 PM »
There is but as I dont have a PSP3000, im not sure how it all works in that regard, cause you may be able to use chickHEN which is even better than patapon exploit. Thats another story though, baby steps, :).
BearClaw
« Reply #6 on: May 28, 2010, 03:18:19 PM »
The psp 3000 is cracked and so is 5.01 hat he needs is a pandora battery with a magic memory stick
Don't feed the trolls, don't feed the trolls, don't feed theaaaaaaaggghhh!
« Reply #7 on: May 28, 2010, 03:38:27 PM »
Dont be so quick to jump in, ;).
The first batch of 3000's are, the second batch are only through chickHEN.
BearClaw
« Reply #8 on: May 28, 2010, 08:06:36 PM »
oooh yeah youre right! sorry it was a while since i used the psp so im hardly updated it seems....
chris2010
« Reply #9 on: May 31, 2010, 08:42:32 AM »
Thanks FOL and BearClaw for your much appreciated help and support! :) I'm still trying to making it run but have no succes until now. I followed FOL instructions but the same error message comes again when trying to run PSPUAE. I have made a PM to FOL (hope I'm allowed to) and have detailed what I've done so far (not to pollute the topic with too much noob questions). I'll keep this topic up to date if I know more and if I'm allowed to will post the whole tutorial once it works. Thanks again!
BearClaw
« Reply #10 on: May 31, 2010, 10:37:59 AM »
have you tried this?
http://www.psp-hacks.com/
and dont worry about the questions, youre asking them in such a polite and well used way
chris2010
« Reply #11 on: May 31, 2010, 02:37:10 PM »
Thanks BearClaw! Yes, while searching for the demo (patapon2) I stumbled upon this site. I'm beginning to learn a little about how everything works. My mistake was to focus on PSPUAE if the first step is being able to make your PSP accepting homebrew stuff (which PSPUAE is if I'm not mistaken). So, in a few days I've leraned a lot here thanks to people as yourself  :) I'm relieved that I'm not out of line asking all these noob questions and hope I'll get this thing running  ;) As soon as I progress I'll let you know more of course.
« Reply #12 on: May 31, 2010, 02:41:47 PM »
I was the same, never heard of homebrew until 2005. Had my PSP on release day and "Followed the instructions" updated and then found out about homebrew, I was gutted, :(.
One thing though, if you have to use ChickHEN, DO NOT install any official firmware over 5.03.
You got PM, Chris.....
chris2010
« Reply #13 on: May 31, 2010, 03:30:07 PM »
« Last Edit: June 01, 2010, 08:07:21 AM by chris2010 »
BearClaw
« Reply #14 on: June 02, 2010, 05:05:41 PM »
THANKS TO FOL AND BEARCLAW FOR THEIR AWESOME SUPPORT! YOU ROCK!
meh FOl did all the hard work as usuall... welcome to the community, and if you need any tips on amiga games that works well on the psp (we talk ofcourse of non-pirated  ;)), any "must play" games or just chill out here you know where to find us mate.
