Oh, hi there guys
Well, seems I'm back and should pick up work eh? Well here we go :
Beta 11: (RC2)- DirectInput keyboard and mouse didn't work in Test/Remap mode after emulation was started
- directory filesystem GUI directory/file selection dialog remembers previous path
- floppy sound disabled channels had different volume level
- XP DX check reverted, for some reason DirectX web installer didn't install all DLLs (including d3dx9_43.dll) when it was released originally, seems to be fixed now
- uaescsi.device: do not send media change interrupt if actual media state didn't change (was possible when changing cdimage0 using uae-configuration), some cd filesystem versions crash(!) in this situation..., fix media detection when switching on the fly from SCSI mode to built-in image mounter. Note that on the fly device changes only works properly if CDFS uses trackdisk.device-style commands (not directscsi) and media change interrupts are enabled (not polling)
- cdimage0= in config file (nothing after '=') means enable built-in image support without media inserted, do not detect and use physical/virtual drives
- renamed pad/joystick POV pairs (1) and (2) to (X) and (Y)
Original post on EAB :
http://eab.abime.net/showthread.php?p=679025#post679025Grab it here :
http://www.winuae.net/files/b/winuae_2200b11.zipWill try to keep this fresh from now on
