Author Topic: Mouse Pointer  (Read 4958 times)
Washac
Mouse Pointer
« on: July 03, 2010, 01:16:20 PM »
Hi All
Finally sat down today and got PSPUAE working on my PSP.
Just a couple of questions at the moment.
I am playing Dungeon Master and would like to know, can the mouse pointer be made to move
a bit quicker and smoother, I assume it is the nature of emulation.
I know there is the aspect ratio 16:9 & 4:3.
Is there a way to get it into full screen ?
That's it, thanks for reading.
« Last Edit: July 03, 2010, 07:28:47 PM by Washac »
Re: Mouse Pointer
« Reply #1 on: July 03, 2010, 08:30:43 PM »
Its all in the readme, ;).
For fullscreen, hold both triggers and select. That will set Auto-zoom.
Mouse Savestates is what you want, set your mouse to desired loaction on screen, then hold both triggers and triangle to bring up mouse savestate menu.
You could try also, altering speed of mouse. By default, triangle is normally toggles mouse slowdown.
delta191
Re: Mouse Pointer
« Reply #2 on: July 04, 2010, 06:57:12 PM »
I can seriously recommend keymapping the PSP's buttons for movement in Dungeon Master.
Thats the key config I use, its much easier to use the mouse pointer for spell casting, combat and opening doors and switches.
use the four PSP's direction buttons for step forward, back, left, right.
use the two PSP shoulder buttons for 90 degree turns left or right.
Dungeon Master is a little odd in the screen size department, I find this the best screensize in pspuae.
hope it helps make things easier for you.  :)
« Last Edit: July 04, 2010, 07:06:15 PM by delta191 »
Re: Mouse Pointer
« Reply #3 on: July 04, 2010, 10:00:59 PM »
hmm.. delta.... i wonder who taught you that ;)
TCD
  • Sir TCD of EAB
  • Backzorz wit da romzorz yo!
    • The English Amiga Board
Re: Mouse Pointer
« Reply #4 on: July 04, 2010, 11:16:42 PM »
Isn't it cute to see them grow up? ;)
Re: Mouse Pointer
« Reply #5 on: July 05, 2010, 12:36:53 PM »
LMFAO.
Washac
Re: Mouse Pointer
« Reply #6 on: July 05, 2010, 05:33:12 PM »
Hi Ya
Very comprehensive reply, thank you very much for this :)
delta191
Re: Mouse Pointer
« Reply #7 on: July 05, 2010, 09:38:51 PM »
I've absolutely no idea what your all on about.....cough....cough   :P
