Author Topic: Eye of the Beholder  (Read 15727 times)
Washac
Eye of the Beholder
« on: July 07, 2010, 11:37:14 AM »
Hi
I have tried and tried all different settings but cannot get EOB running under PSPUAE :(
Also how do you play games with more than 2 disks, how do you disk swap ?
Any help with with this would be good :)
Thanks....
« Last Edit: July 07, 2010, 11:43:52 AM by Washac »
Re: Eye of the Beholder
« Reply #1 on: July 07, 2010, 03:09:22 PM »
Hi
Thanks....
Have you read the readme?
Press select for the Emulator menu, all settings can be altered there.
You can also change disks there.
Washac
« Reply #2 on: July 07, 2010, 03:31:18 PM »
Hi
Thanks....
Hi
As said I have tried and tried all different settings, different CPUs, RAM, ECS, OCS with no luck.
« Reply #3 on: July 07, 2010, 07:50:59 PM »
hm.. im sure is rdy run this game
i can see Delta videos on FAT PSP :
try to test other disk (adf) images ..
http://www.youtube.com/watch?v=8RnAC9jwY5M
http://www.youtube.com/watch?v=6tOkLOyvxtE&feature=related
Washac
« Reply #4 on: July 07, 2010, 09:21:10 PM »
Hi
Once i got home I downloaded a different set of ADFs and it all works now, well except the sound which is all sort of stuttering :(
I am using the slim version of PSPUAE, if this helps, or makes a difference.
« Last Edit: July 07, 2010, 09:41:43 PM by Washac »
« Reply #5 on: July 07, 2010, 09:49:51 PM »
Hi
You need to tweak settings.
Try Cpu Turbo or CPU 2 CHIPSET options.
Washac
« Reply #6 on: July 07, 2010, 10:16:22 PM »
Hi
Hi
I assume you mean CPU MAX, I can find no turbo setting.
CPU 2 CHIPSET - Lost me on this one
« Last Edit: July 07, 2010, 11:25:07 PM by Washac »
Washac
« Reply #7 on: July 08, 2010, 11:37:12 AM »
Hi
Just thought I would add that the sound is even more choppy when the PSP is reading the Mem Card.....
« Reply #8 on: July 08, 2010, 06:36:14 PM »
Hi
The options I mention are in the menu, where you change the cpu, you will find "turbo" mode.
If Delta got it running fine, then Im sure you will crack it.
@Delta, if you see this, can you post your Eye Of The Beholder config.
delta191
« Reply #9 on: July 08, 2010, 07:29:27 PM »
will have a look, though the videos were version 0.72.
I always remember EOB being alot more troublesome than most games in the config department. I still have all the configs for 0.72 games, sure I can dig something out, then try and adjust things for 0.80.
try these settings, my 0.72 savestate works ok on 0.80, just loaded it up ok.
« Last Edit: July 08, 2010, 07:38:21 PM by delta191 »
Washac
« Reply #10 on: July 08, 2010, 07:44:58 PM »
Hi
Thanks for the settings, sound is still a mass of crackles and real choppy : )
I am running 0.72
delta191
« Reply #11 on: July 08, 2010, 07:57:58 PM »
Dont know why the sound is so bad for you, here's the sound settings.
Washac
« Reply #12 on: July 08, 2010, 08:22:18 PM »
Hi
Done all your settings sound still the same, thanks for the help :)
Are you using a FAT or SLIM PSP ?
« Last Edit: July 08, 2010, 08:25:18 PM by Washac »
« Reply #13 on: July 08, 2010, 08:47:48 PM »
You could try the FAMEC version of PSPUAE.
Washac
« Reply #14 on: July 08, 2010, 09:15:18 PM »
Hi
OK, tried the FAMEC version tried to load EORB and after a bit the PSP shuts down....
I do appreciate peoples efforts on this :)
