Author Topic: How to get permission to download  (Read 4553 times)
braynor
« on: January 01, 2011, 03:30:36 AM »
I am a new member, and would like to download the E-UAE for OSX package. When I attempt to do that, I get a message that "You are not allowed to access this section." (although the mirror link works. How do I access the downloads section?
Thanks
Bill
Re: How to get permission to download
« Reply #1 on: January 01, 2011, 12:12:06 PM »
People really need to search.
Its a known bug on the site, I have'nt had time to fix it as yet.
Try now.
« Reply #2 on: January 01, 2011, 01:34:57 PM »
I'm afraid you'll have to stick with the mirror link for that particular file.
http://www.ultimateamiga.co.uk/index.php/topic,4329.0.html
You could post 200 posts and then i think all your permissions would work :)
i hate to say it though FOL, but the problem does really need sorting :S
« Last Edit: January 01, 2011, 01:36:59 PM by Hungry Horace »
« Reply #3 on: January 01, 2011, 11:27:18 PM »
200 Posts arent needed.
Its a very wierd bug.
If I access account, with problem and click save, where by saving 0 posts. It tends to fix it.
Im not sure when it started though, server move?
After 3 site merge?
« Reply #4 on: January 02, 2011, 12:13:29 AM »
i have no idea what caused it.
i assume you tried deleting all the membership groups and whatnot?
« Reply #5 on: January 03, 2011, 01:27:39 AM »
I did, but problem transfered to next user group.
« Reply #6 on: January 11, 2011, 10:01:05 PM »
This problem is now solved.
If you registered while we had the issue, then you may have to pm me.
So I can fix your account.
OFF TOPIC,
10,000th POST, :).
« Last Edit: January 11, 2011, 10:13:46 PM by FOL »
