Author Topic: GUI Help  (Read 4195 times)
Dreedo
GUI Help
« on: January 06, 2011, 01:17:46 PM »
Hi i was wondering what the numbers mean at the side.
Obviously i worked out power and the top 2 being the floppy drives, i think one of the bottom ones is the FPS. But can anyone tell me exactly what they are?
Nvm i think i got it:
Power
DF0:
DF1:
Frameskip
FPS
Emulation Speed
is that right?
« Last Edit: January 06, 2011, 02:31:01 PM by Dreedo »
Re: GUI Help
« Reply #1 on: January 06, 2011, 07:17:01 PM »
| |-Misc = All uncategorized options
|   |-Mouse Speed = How fast you want the mouse, 1 to 5, 1 = Slow / 5 = Fast
|   |-High Res Mouse Speed = How fast you want the mouse in High Res mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Auto Mouse Speed = How fast you want the mouse in Auto mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Show LED's = Shows the Power, Drives, Frame Rate & Emulation speed
|   |-Transparent Keyboard = Lets you make the OSK, Solid or Transparent
|   |-Disabled Key Combo's = Turns off all key combo's, i.e. Screen move, will not work if this is "ON"
|   |-Toggle X & O = Use this option if you have a Japanese PSP, switched the X & O around
|   |-Background Image = Use this to turn Menu Backdrop "ON" or "OFF"
http://www.ultimateamiga.co.uk/index.php/topic,431.0.html
it is in the readme afterall ;)
there's a PSPUAE link on the front page with a few such topics linked to which you might find handy?
Dreedo
Re: GUI Help
« Reply #2 on: January 06, 2011, 08:37:22 PM »
I dont tend to use a PC when using my PSP, so i dont read readmes often, just download directly to my PSP and install it.
And thanks.
Re: GUI Help
« Reply #3 on: January 06, 2011, 10:02:59 PM »
And thanks.
Hey dreedo, you finally up and running, ;).
Dreedo
Re: GUI Help
« Reply #4 on: January 07, 2011, 12:02:04 PM »
Yeah round my nans at the moment, PSPUAE being a lifesaver, played Lotus 1 for the first time, got to like Race 6 then got frustrated at being cut up... :P Then played Nitro for a bit, got it to run at pretty much 100% now.
