Author Topic: Did you know?  (Read 4239 times)
Offline grasstust
Did you know?
« on: February 10, 2008, 09:30:36 PM »
VLC plays Amiga MODs!
Offline Hungry Horace
Re: Did you know?
« Reply #1 on: February 10, 2008, 09:43:14 PM »
err... i didnt know that - this is well useful!
It seems it also plays OctaMED files.... alas, not correctly.  It doesnt force the 3-octave limit that it should. This makes me suspect it uses the same library as Milkytracker/player... since this bug was also present on the PSP application 'modo'
i guess i'll have to be a bit less sloppy with my use of octaves!
