Author Topic: MacVICE  (Read 104745 times)
Offline MagerValp
Re: MacVICE
« Reply #15 on: March 11, 2008, 09:30:16 AM »
Just noticed another bug: right shift doesn't seem to do anything. Left shift works as expected. 10.5.2, swedish pro keymap, core duo macbook.
Offline franticHT
    • Little Computer People Demo Party
Re: MacVICE
« Reply #16 on: March 13, 2008, 06:00:23 PM »
Although I do agree that the square form of those Icons make them a little bit less unique, I still think they are definitely good enough to be fully useablem and I certainly would not be disturbed by them. :)
Diskimagery64 has nice icons for C64 filetypes. (At least I think that's where the icons in my system for .d64 files and so on came from.) The .d64 icon is a 5.25" disk with a label saying "data" on it. :) Perhaps the same icons could be used for the filetypes?
...and now I just remembered that the same person is behind those two projects. :)
//FTC
Offline MagerValp
Re: MacVICE
« Reply #17 on: March 13, 2008, 09:25:11 PM »
Indeed :) The icons have to be redrawn for 512x512 anyway though.
I also found another bug: you can't drag & drop CRT files, it tries to load them as a PRG.
Offline MagerValp
Re: MacVICE
« Reply #18 on: March 17, 2008, 08:31:14 PM »
OK, the VICE application icons are done. You can grab them here:
http://www.cling.gu.se/~cl3polof/vice/vice-macosx-icons-r1.zip
The Photoshop images are included if anyone wants to improve them.
A few demo shots of the icons follow:
Offline MagerValp
Re: MacVICE
« Reply #19 on: March 18, 2008, 01:34:32 PM »
Here's the first mockup of the tape icon:
Offline MagerValp
Re: MacVICE
« Reply #20 on: March 18, 2008, 04:29:09 PM »
And here's the cartridge mockup:
Offline MagerValp
Re: MacVICE
« Reply #21 on: March 18, 2008, 07:27:41 PM »
...and D64:
Edit: fixed shadow
« Last Edit: March 19, 2008, 11:11:58 AM by MagerValp »
Offline MagerValp
Re: MacVICE
« Reply #22 on: March 19, 2008, 11:12:54 AM »
OK, tape, cartridge, and 5.25" floppy icons added.
http://www.cling.gu.se/~cl3polof/vice/vice-macosx-icons-r2.zip
Offline lallafa
  • MacVICE & DI64 Dev
    • lallafa's Blog
Re: MacVICE
« Reply #23 on: March 19, 2008, 08:06:19 PM »
The icons are really awesome! If you agree I'll add them to "official" VICE (with proper artist reference) and of course to the next snapshot....
Now only a PRG Icon is missing (ok, i forgot vsf)... but this one is rather abstract... ;)
BTW: The old DiskImagery64 icons were done in SVG and so they are available in any resolution ;)
Offline MagerValp
Re: MacVICE
« Reply #24 on: March 19, 2008, 08:20:21 PM »
Yes, please use them as you see fit. I think they could use a little more work, in particular the media icons needs better text, and maybe a little color?
PRG, VSF, and D81 needs to be done. D81 is easy enough, but I don't know how to visualize PRG and VSF. As you say they are a little abstract...
Offline lallafa
    • lallafa's Blog
Re: MacVICE
« Reply #25 on: April 06, 2008, 07:32:27 PM »
a new snapshot is online: vice-1.22.9-r422_20080406
changes:
* updated to VICE 1.22.9
* readded FFMPEG support
* added MagerValp's icons
Offline MagerValp
Re: MacVICE
« Reply #26 on: April 06, 2008, 08:31:42 PM »
Looking good. The xplus4 and xvic icons need to be made a little bit darker, so that the screen glare is visible. Also, how do I get the new vice icons to become the default document icons for D64, etc? My system appears to be using icons from the official VICE 1.21.
I noticed that fullscreen mode is available, but the menubar and dock stays visible. It also doesn't keep the aspect ratio, but gets squashed on my macbook's widescreen display.
Offline lallafa
    • lallafa's Blog
Re: MacVICE
« Reply #27 on: May 04, 2008, 07:32:00 PM »
a new snapshot is online: VICE 1.22.12-r18765_20080504
this time:
  • added Snapshot/Quick Snapshot
  • added auto-hide menu in fullscreen mode
  • added auto-hide mouse in emulator window
  • fixed aspect ratio in fullscreen mode
  • updated to 1.22.12
  • source now taken from official SVN Repository at vice-emu.sf.net (cocoa-branch)
Offline MagerValp
Re: MacVICE
« Reply #28 on: May 04, 2008, 08:10:48 PM »
Yay!
Must... fix... icons...
Offline lallafa
    • lallafa's Blog
Re: MacVICE
« Reply #29 on: May 18, 2008, 09:33:29 PM »
new snapshot: MacVICE-1.22.15-r18792_20080518
  • added Resource Inspector for editing machine resources
  • updated to 1.22.15
BTW: VICEplus 1.1 was released. First time with Cocoa binary and my latest Cocoa changes merged from MacVICE. see: http://viceplus.wiki.sourceforge.net/
