Author Topic: Mac and C64 connectivity: Status?  (Read 2999 times)
Offline Itekei
« on: April 07, 2008, 02:52:28 PM »
In older days I've been using a XE1541 cable to connect PC and CBM drive. Please give me an update on how to connect a Mac to a C64/CBM drive nowadays. Via RR-Net? Thanks!
Offline lallafa
  • MacVICE & DI64 Dev
    • lallafa's Blog
Re: Mac and C64 connectivity: Status?
« Reply #1 on: April 07, 2008, 05:24:22 PM »
The newer XU1541 device connects a IEC device like a 1541 directly to USB. With the current CVS version of OpenCBM you can use this device to copy files, format disks, write images on the command line.
Here are the details: http://www.trikaliotis.net/xu1541
You have to built this device yourself and compile a CVS version of OpenCBM for it.
I did that and can say that it really works fine on a Mac.
With a RRNet+MMCReplay cartridge you can directly connect your C64 via ethernet cross-cable to your Mac. With DiskImagery64 on your Mac and the Final Replay ROM on your MMCReplay you can easily transfer disk images in both directions.
