Author Topic: OpenCBM for Mac (and XU1541)?  (Read 6885 times)
Offline anemo
« on: December 16, 2009, 08:00:59 PM »
Hi!
I'm looking for a way to connect a 1541 to my MacBook and the XU1541 + OpenCBM seems to be the best solution right now. But I can't find a compiled version of OpenCBM (CVS?) for Mac and also wonder if it's used via command line or is there a GUI?
1xC64 ('82 Breadbin) | 2x1541 | The Final Cartridge III | Epyx FastLoad | XM1541 | Bunch of joysticks
iPhone with C64 emulator | MacBook Pro with C64 emulator
Offline lallafa
  • MacVICE & DI64 Dev
    • lallafa's Blog
Re: OpenCBM for Mac (and XU1541)?
« Reply #1 on: December 19, 2009, 07:29:13 PM »
The CVS version of OpenCBM supports the Mac. You have to compile it yourself, but it has a MacPorts portfile included so setting up is no big deal.
Both the XU1541 and the XUM1541 devices work on the Mac with OpenCBM. However, I would recommend the XUM1541 device because it supports more features (including parallel transfers and in near future even nibbling) and the project is still in active development.
I have written a detailed tutorial on how to setup and use OpenCBM on your Mac: OpenCBM on Mac
Offline anemo
« Reply #2 on: December 20, 2009, 03:12:11 PM »
Hi Lallafa!
We have discussed this earlier if you can remember :)
I have no clue how to compile stuff. What program do I use to start with? And does OpenCBM (CVS) include a GUI or is it command line only?
Offline lallafa
    • lallafa's Blog
« Reply #3 on: December 21, 2009, 03:00:19 PM »
OpenCBM is a set of command line tools.
Installing the software is no big deal.
Have a look at my page. 5 easy steps are required and everything is installed on your Mac.
You can also see there the typical commands to copy disks and files.
