Author Topic: Amiga Specs  (Read 9531 times)
Amiga Specs
« on: July 29, 2006, 04:14:14 PM »
Amiga 1000
AMIGA SYSTEM SPECIFICATIONS
MEMORY
    * 256K Bytes RAM standard
    * User expandable to 512K Bytes RAM internally
    * Externally expandable to eight megabytes continuous RAM
    * 256K Bytes Writable Control Store
MAIN PROCESSOR
    * MC68000
    * 32 Bit internal bus
    * 16 Bit data bus
    * 7.16 MHz clock speed
THREE CUSTOM VLSI CHIPS:
CUSTOM GRAPHICS CHIP
    * Many different resolutions - 320x200 32 colors, 320x400 32 colors, 640x200 16 colors, 640x400 16 colors
    * Color palette of 4,096 colors
    * Eight, re-usable, 16-bit wide sprites
    * 60/80 column colored text
    * Programmable interobject priority and collision detection
    * Compatible with RGB analog monitors, NTSC composite monitors and home televisions
CUSTOM ANIMATION CHIP
    * Utilized a Bit-Blitter for high speed movement of graphical data.
    * Allows high speed animation
    * Frees the CPU for other concurrent tasks
    * Display synchronized coprocessor
    * Controls 26 DMA (direct memory access) channels
CUSTOM SOUND/PERIPHERALS CHIP
    * Four voices of sound output as two channels
    * 9 octaves
    * Complex waveforms allow high quality speech and musical instrument synthesis
    * Uses both amplitude and frequency modulation
    * I/O controls for disk data and mouse/joystick controller ports
    * Allows the disk and sound to operate with minimal CPU intervention
OPERATING SYSTEM
    * AmigaDOS
    * Multi-tasking
    * Hierarchical file system allows fast file access and hard disk compatibility
USER INTERFACE
    * "Intuition"
    * Pull down menus
    * Mouse or keyboard controlled
    * Color
    * Up to 50 overlapping windows, each running simultaneously in real time
    * Features the "Workbench" iconic user interface
    * Also features a Command Line Interface (CLI)
PREFERENCES
    * User selectable background and character colors, keystroke speed, mouse speed, mouse pointer editor and font size
    * Peripheral parameters for printers and modems
KEYBOARD
    * Detachable, full-size typewriter style
    * 89 keys total
    * 13 key numeric keypad
    * 10 programmable function keys
    * 2 special function keys
    * 4 directional cursor keys
    * HELP key
DISK DRIVE
    * 3.5" Micro floppy disk drive
    * Double sided double density
    * 880K Bytes formatted storage capacity
    * Maximum transfer rate of 250 kilobits per second
    * DMA controlled read and write for fast disk access
MOUSE
    * Two button optomechanical
    * Eliminates the need to learn commands
    * Works well on any surface
AUDIO OUTPUT
    * Two RCA audio output jacks
    * Signal to noise ratio 70db
    * Distortion less than 1%
    * Frequency response 20-6,000Hz
    * Impedance 300 ohms
INPUT/OUTPUT
    * Analog RGB video port
    * RF modulator video port for home television
    * NTSC composite video port
    * Two reconfigurable controller ports (supports mouse, joysticks, paddles, light pens and custom controllers)
    * External floppy disk port
    * RS232 serial port
    * Reconfigurable Centronics parallel port
    * Expansion port
    * RAM expansion port
    * Keyboard connector
BUNDLED SOFTWARE
    * AmigaDOS
    * Amiga BASIC
    * Amiga Tutorial
    * Kaleidoscope
    * Voice Synthesis Library
WEIGHT
    * Approximately 13 lbs.
DIMENSIONS
    * 4.25" x 17.75" x 13" (H x W x D)
POWER REQUIREMENTS
    * 120V, 90 Watts, 60Hz, 1A nominal
RECOMMENDED PERIPHERALS
    * 1080 Amiga Monitor
    * 1010 External 3.5" Disk Drive
    * 1020 External 5.25" Disk Drive
    * 1050 Memory Expansion Cartridge
    * 1680 Modem 1200 RS*
    * 1025 Amiga Transformer*
    * 3406 RF Modulator
    * 1300 Genlock Interface*
    * 1100 AnswerMate*
COLOR
    * Standard Amiga Light Beige
Amiga 500
    * Motorola MC68000
    * 7.16 MHz CPU
    * 512k Chip RAM or 1 megabyte Chip RAM on motherboard
    * Maximum 512k (A500) or 1 megabyte Chip RAM (A500+)
    * 512k Fast RAM in trapdoor expansion bus (optional)
    * Maximum 8 megabytes Fast RAM
    * 512k RAM (A500) or 1 megabyte RAM (A500+) on motherboard
    * 256k ROM or 512k ROM on motherboard
    * 3.5 drive bay 2.5 drive mountable
    * 3.5 880K internal floppy drive
    * Integrated keyboard
    * 2 button mouse
    * A1000 sidecar expansion bus
    * A500 trapdoor expansion bus
    * Compact case
    * External power supply port
    * External floppy drive port
    * RS-232 serial port
    * Centronics parallel port
    * 2 mouse/joystick ports
    * Monochrome composite video port
    * 15kHz colour RGB analogue video port
    * 2 stereo audio output ports
Amiga 2000 (Later known as the Amiga 1500)
CPU    68000@7.14 Mhz
Custom Chips    Denise - 8362 Denise, REV6.3+ had 8373 SuperDenise
Paula
Fat Agnus
Gary
Buster    ZorroII Buster DIP
Video    OCS or ECS (4096 colors)
Kickstarts    1.2, 1.3 then 2.04
Memory    Memory varied according to the hardware revision.
The 3.x revisions found in German models use 512Kb Chip RAM on their motherboard and 512Kb Fast RAM on a processor card.
Revision 4.x, the American edition, had both 512Kb Chip and Fast RAM soldered onto the motherboard.
Later versions of the B2000 and C2000 based upon revision 6.x design included 1 Mb Chip RAM.
Drives    Internal 880K floppy
SCSI HD in 2000HD models
Drive bays    2x 3.5" front bays
1x 5.25" front bay
(in the A1500 model both of the 3.5" bays are occupied with 880Kb DD floppy disk drives.)
Slots    1 - Video
1 - CPU
5 - Zorro II
2 - 8 bit ISA
2 - 16 bit ISA in line with Zorro II slots
Interfaces    1x Serial DB25 male, RS232
1x Internal serial 26 pin header
1x Parallel DB25 female, Centronics
1x Video DB23 male, analog RGB
1x Composite, black & white
2x Mouse/game DB9 male
2x Stereo audio RCA jack
1x Keyboard 5 pin DIN female
1x External floppy DB23 female
1x Internal floppy 34 pin header
Amiga 3000
CPU    68030 at 16 or 25 Mhz
FPU    68881-16Mhz or 68882-25Mhz
Custom Chips    Denise - 8373 SuperDenise
Paula
Agnus - 8372B Agnus for 2 meg CHIP RAM
Fat Gary
Amber - De-interlacing chip to provide 31KHz video
SuperBuster -07, -09 and -11
SuperDMAC -02, -04
Ramsey -04 and -07
Video    ECS (4096 colors)
Kickstart    1.3 and 2.04
Memory    1-2Mb Chip RAM, up to 16M FAST (Zip)
Drives:    Internal 880K floppy
SCSI-2 Hard drive
Slots    1 - Video
1 - CPU
4 - Zorro III
2 - 16 bit ISA in line with Zorro III slots
Ports    Mouse
Joystick
Parallel
Serial
15Khz RGB video
31Khz RGB video (Flicker fixer)
External Floppy
External SCSI-2 Connector
5-pin DIN Keyboard connector
Stereo RCA Audio jacks
Black & White composite video output
Amiga 500+
    * Motorola MC68000
    * 7.16 MHz CPU
    * 2 button mouse
    * Compact case
Amiga CDTV
CPU: 68000 at 7.14 Mhz
FPU: None
Video: ECS (4096 colors)
Kickstart: 1.3 (+ additional CD support).
ROM size: 192 Kb
Memory: 512k (later expanded to 1Mb Chip RAM)
Custom Chips:
    * Denise - 8373 SuperDenise
    * Paula
    * Agnus
      Gary
Drives:
    * Internal Single speed CDROM
Slots:
    * 1 - Credit card type (to save games scores)
    * 1 - Video
    * 1 - DMA extension
Ports:
    * Mouse & Infrared Joystick
    * Parallel
    * Serial
    * 15Khz RGB video
    * External Floppy
    * Stereo RCA Audio jacks (16 bit)
    * Colour composite Video output
    * MIDI In/Out
    * Headphone Jack
Amiga 3000T (Tower)
Paula
Fat Gary
SuperDMAC -02, -04
Ramsey -04 and -07
SCSI-2 Hard drive
Slots    1 - Video
1 - CPU
4 - Zorro III
Ports    Mouse
Joystick
Parallel
Serial
15Khz RGB video
External Floppy
Amiga 600
CPU:               Motorola (R) 68000, 16/32 bit 7.16 MHz NTSC Multi-Chip coprocessor system for DMA, Video, Graphics and Sound
Memory:    Expandable to 2MB Chip RAM Maximum RAM expansion 6MB with PCMCIA 512KB ROM
Software:    AmigaDOS (TM) Release 2 Multitasking Operating System in ROM Workbench 2.X and Utilities software
Keyboard:    Integral 78 Key International
Mouse:             Opto-mechanical 2-button design
Disk Drives:     Built-in 3.5-inch 880 KB floppy disk External 3.5-inch floppy disk Internal IDE hard disk drive (optional)
Graphic modes:    Colour palette of 4096 colours Selectable resolutions Supports full overscan
Video Output:      RGB analogue 15 kHz Horizontal Scan Rate Colour Composite RF Modulated
Sound:    Four channel stereo sound
Dimensions:      14" deep x 9.5" wide x 3 high
Weight:        Approx. 6 lbs.
Power Requirements:    Switching power supply 23 watts
External Interfaces:
    * Floppy Disk (DB23)
    * Mouse/Joystick/Lightpen (2 DB9)
    * Serial (RS-232, PC-compatible)
    * Parallel (Centronics -- PC-compatible)
    * Video RGB analogue (DB23 15 kHz)
    * Colour Composite (RCA)
    * RF Modulator (RCA)
    * PCMCIA Card Slot
Internal Interfaces:    Internal AT IDE connector
Amiga 4000/040 / 030
CPU
    * Motorola (R) 68040 series 32-bit processor
    * 25 MHz clock speed
    * Removable processor module
Memory
    * 2 MB 32-bit Chip RAM
    * Up to 16 MB 32-bit Fast RAM
    * Easily expandable via standard SIMM units
    * Additional standard RAM is supported by the Amiga's proprietary AUTOCONFIG (TM) capability
Software
    * 512 KB 32-bit ROM
    * AmigaDOS (TM) 3.0 Multitasking Operating System
    * Supports programmable resolutions
    * Supports outline fonts
    * Localized for multiple language/countries
    * CrossDOS MS-DOS (R) file transfer utility
Interfaces
    * Keyboard
    * Mouse/Joystick/Lightpen/Tablet ports (2)
    * Serial (RS-232)
    * Parallel (Centronics)
    * Video (RGB analogue or RGBI digital)
    * Right and Left stereo audio
    * Internal and External floppy disk drive ports
    * Internal AT IDE port. Optional SCSI adapter
System Slots
    * CPU slot (200-pin) supports high-speed memory and advanced processors
    * Amiga system bus
    * Four 16/32-bit Zorro III expansion slots (100-pin) with AUTOCONFIG
    * PC bus
    * Three PCAT T(M) slots
Video Slots
    * Extended 24-bit Video slot
    * In line with standard 100-pin Zorro slot for easy integration of Zorro and video boards
Zorro 3 Expansion slots
1, 2, 3 = PC/AT Slots; 4 = Video Slot
How the Slots Work:
If MS-DOS compatibility is desired a Bridgeboard may be placed in slot 1, 2, or 3. When a Bridgeboard is installed, the empty PC slots are capable of supporting a variety of XT or AT- style boards. The remaining Zorro III slots support both 24 & 32-bit Zorro boards.
Keyboard
    * Detachable
    * 94 keys, including 10 function keys
    * Separate numeric keypad
    * Separate cursor keys (inverted "T" layout)
Mouse
    * Opto-mechanical
    * 2-button design
Disk Drives
    * Built-in 3.5-inch high density disk drive (880 KB/1.76 MB formatted)
    * Hard Drive models pre-formatted and pre-loaded with system software and utilities
    * 2 rear and 2 front 3.5-inch drive bays
    * 1 front 5.25-inch drive bay
Graphics Modes
    * AGA custom chipset produces resolutions ranging from 320x200 to 1280x400 (more with overscan), including 800x600
    * NTSC and PAL video resolutions
    * Colour palette of 16.8 million colors
    * 2 to 256,000 user-definable colours displayable on screen
Video Display Output
    * Works with RGB analogue VGA or multiscan monitors (not all modes supported with non multiscan monitors) - Horizontal scan rates 15 kHz - 31 kHz
    * Vertical scan rates 50 Hz - 72 Hz
Sound
    * Four channel stereo sound, capable of reproducing complex waveforms
    * 8-bit D/A converters
    * 6-bit volume
Dimensions
    * 15 1/4" deep x 15" wide x 5 high
Weight
    * Approx. 20 pounds
Power Requirements
- 110 volt/60Hz 150 watt power supply
Amiga 1200
    * Motorola MC68EC020 14.32 MHz CPU
    * 2 megabytes Chip RAM on motherboard
    * Maximum 2 megabytes Chip RAM
    * 512k ROM on motherboard
    * 3.5 drive bays
    * 2.5 drive mountable
    * 3.5 880k internal floppy drive
    * 2.5 40 megabyte IDE hard drive (optional)
    * 96 keys
    * 10 function keys
    * Numeric keypad
    * Cursor keys (inverted T layout)
    * 2 button mouse
    * A1200 trapdoor 150 pin local bus expansion
    * PCMCIA 2.0 expansion bus
    * Compact case
    * Colour composite video port
    * 31KHz SVGA video output
    * 32 BIT data path
    * 24 BIT address space
    * Optional battery backed clock
    * Weight: 8 lbs.
    * 9.5" deep x 18.5" wide x 3 high
    * 110 volt/60Hz 23 watts power supply (external)
Amiga CD32
CPU                             68EC020@14.28 Mhz
Custom Chips                Lisa, Alice, Paula & Akiko
Video                             AGA
ROM                            Kickstart 3.1
Memory                        2Mb Chip RAM,
                                   1k flash ram (for games scores)
Drives                             Double-speed internal CD-ROM
Ports                             Mouse
                                   Joystick
S-Video output              15Khz-31Khz RGB video
                                   Headphone jack
Amiga 4000T / 060 (ESCOM VERSION)
    * Motorola MC68040 25 MHz CPU
    * CPU on expansion card in CPU slot
    * CPU card may be removed and exchanged for a different card
    * CPU card compatible with A3000T, A4000/030 and A4000/040
    * 68040 25 MHz FPU - 68040 FPU emulates 68882 FPU on expansion card
    * 2 megabyte Chip RAM on motherboard
    * Expandable to 2 megabytes 32 BIT Chip RAM
    * 4 megabytes Fast RAM on motherboard
    * Expandable to 16 megabytes 32 BIT Fast RAM
    * Expandable using SIMM modules
    * 512K ROM on motherboard
    * 32 BIT architecture
    * 5.25 internal drive bay
    * 4 3.5 drive bays
    * 3.5 1.76 megabyte internal floppy drive
    * 3.5 210 megabyte SCSI II hard drive
    * SCSI II hard drive controller
    * Detached keyboard
    * 3 button mouse
    * 5 Zorro III 32 BIT Amiga internal expansion slots
    * 4 IBM AT internal expansion slots
    * 2 inline with 2 Zorro III slots
    * Internal 32 BIT CPU expansion slot
    * 2 internal 24 BIT extended video expansion slots
    * Floor mountable tower case
    * Internal 250 WATT power supply
    * Internal fan - External floppy drive port
    * 53.5cm x 50.8cm x 18cm
