Author Topic: E-UAE for PS3 (GameOS) Released  (Read 6193 times)
« on: February 06, 2011, 10:18:39 AM »
Some great news... it seems 'Ole' has ported E-UAE over to homebrew-enabled PS3's using the psl1ght sdk.
Quite the extent of the adaption to PS3, I cannot tell you yet, but this is a pretty exciting development.
Now, if anyone can actually locate the author, perhaps we could drag him here... :)
E-UAE 0.8.25 for PS3  release 3
- compiled by using psl1ght sdk
- The full uae documentation is stored in the 'docs' subdirectory, here
  you are reading the ps3 port info.
Features:
- 68000, 68010, 68020 processor cores
- OCS, ECS and AGA chipset
- amiga hi-res (720x576) graphics resolution in 32bit depth
- joystick1, joystick2 (2nd joypad required) and mouse emulation
- simple options dialog (supports switching of the disk files and more)
- sound in 48000 kHz
- keyboard emulation
- support for loading zip and dms floppy images
- reads either /dev_usb000/uae/uae.cfg or /dev_hdd0/game/EUAE00825/USRDIR/UAE.CFG
  configuration during startup!
Requires:
- ps3 ready to boot homebrew programs
- uae.cfg either in /dev_usb000/uae/ or /dev_hdd0/game/EUAE00825/USRDIR/ directory
  (sample UAE.CFG included)
- kickstart rom - see docs/readme
Controls:
- press R2 to activate virtual keyboard (vkb), release R2 to hide it.
  If vkb is shown press left/right digital pad to select the current
  key. Press the 'up' digital pad button to actually simualte key press
  of the current key. L1, L2, R1 ann CIRCLE buttons are user defined keys.
  If vkb is shown press L1 to define L1 button, press L2 to define L2 button
  and press R1 to define R1 button.
- joypad 1 (emulates joystick 1 and mouse 1)
- joypad 2 (emulates joystick 2) - if you want to enable 2-joystick mode, plug-in
  the second joy pad, restart uae and switch the port mode to "joy-1 & joy-2" in the
  options dialog.
- left analog pad emulates the mouse movement. You can speed-up the mouse movement
  in the options dialog.
- CROSS    - joystick button 1
- SQUARE   - mouse button 1
- TRIANGLE - mouse button 2
- press Start to enter application menu, here you can load ADF files.
- press CIRCLE to exit the application menu
Additional info:
- The program reads uae.cfg during startup. In this configuration file
  you should specify all required parameters (memory size, kick rom, initial
  floppy disk files, cpu core, chipset etc.).
- Files (kickrom, adf files) are accesible from either usb disk or internal disk.
Credits and thanks:
- UAE team and porters.
- RCDRUMMOND for E-UAE
- psl1ght sdk team
- PS3 homebrew scene
Release log:
r3
- options dialog has more space for filenames
r2
- added support for uae.cfg stored on hdd
r1
- initial release
Ole
source: http://www.volny.cz/molej/ps3/index.htm
download: http://www.volny.cz/molej/ps3/e-uae-0.8.25-ps3_r3.zip
source code: http://www.volny.cz/molej/ps3/e-uae-0.8.25-ps3_r3_src.rar
« Last Edit: February 06, 2011, 09:39:39 PM by Hungry Horace »
seuden
  • Amiga Online Gamer
Re: E-UAE for PS3 (GameOS) Released
« Reply #1 on: February 07, 2011, 08:27:39 PM »
It is great news and I can't wait to try it.  If you're thinking of getting him here tho don't hold your breath as I've heard getting hold of him is as rare as hens teeth!!
Dreedo
« Reply #2 on: March 02, 2011, 09:29:49 AM »
Just to update, incase noone follows this on the EAB.
MickJT has been updating this to the latest e-uae version. Done some improvements such as support for 2 mice, so Lemmings and Settlers 2 player modes now fully work i can confirm. Also added support for changing which analog stick controls the mouse/joypad, bit weird, but PS3 analogs have been known to break, so possibly useful. Also has the ability to recognize PAL/NTSC modes. He's also added savestates, which are useful.
