Author Topic: xec.library continued  (Read 4024 times)
robertframpton
« on: July 31, 2006, 02:25:29 PM »
Continuing from my last post.
  The only library on the disk is Amos.library which is included with the compiled program executable.
  I have not put a LIBS directory on the disk, so I have not used any libraries.
Re: xec.library continued
« Reply #1 on: July 31, 2006, 04:43:46 PM »
AMOS internally uses IEEEMathTrans.library and others to perform its internal math functions.  It won't start without a libs directory populated with at least 4 or 5 math libraries that it uses internally.
I have seen bootable games written in AMOS before but I don't have a classic Amiga with floppy drive hooked up at the moment as it is waiting for a new accelerator board.  Maybe sombody else here can list off the libraries that Amos uses.
By the way, if you want to continue a previous thread on this web page, use the REPLY on that topic thread instead of starting a new topic every time.
« Reply #2 on: August 01, 2006, 03:58:49 AM »
The AMOS Professional boot disc has the following libraries in the "libs" directory:
amos.library
diskfont.library
icon.library
mathieeedoubbas.library
mathieeedoubtrans.library
mathtrans.library
medplayer.library
translator.library
Hopefully this will help.  You should be able to copy these library files from any amos boot disk or from a workbench disk.
