Author Topic: Need some help with a text-engine  (Read 4967 times)
puni_gds
    • http://www.classicamiga.com
« on: January 27, 2007, 07:14:59 PM »
I'm quite new to this forum, as I registred only a few weeks ago. Currently I'm trying to create a small program that plays Protracker modules. I've managed to set up a selector for the modules, which seems to be working ok. Along with the module selector, I would also like to implement a small section with articles. This section will be placed on the right side of the screen and limited to a medium sized black box.
It has been many years since I last did some coding, and I'm really having difficulties with the text-routine. The thing I'm trying to do is as follows:
Have a menu like this: (just an example)
Article 1
Article 2
Article 3
Article 4
Article 5
When I click on Article 1, I want it to show the relevant text in the same box. I've tried using the set zone command, along with the ordinary text command, but it is not working as I want. Are there any other ways of doing this? Hope to receive some input on how to view short texts in a box, and how you can switch between them.
Thanks in advance for your help. :)
Please feel free to visit Classicamiga
- Your guide for everything Amiga!
Re: Need some help with a text-engine
« Reply #1 on: January 28, 2007, 05:40:13 PM »
Welcome to the Amos Factory puni_gds.  Here is a quick and dirty example of how I would do what you describe using AMOS text windows:
Screen Open 0,640,200,8,Hires
Wind Open 1,472,0,21,10,1
Border 0,0,2
Paper 0
Curs Off
Reserve Zone 10
Do
   Proc CREATE_MENU
   Proc CHECK_ZONES
   CLICKED_ZONE=Param
   'Use CLICKED_ZONE to find which zone was clicked and load the article
   If CLICKED_ZONE=10
      End
   Else
      Proc DISPLAY_ARTICLE[CLICKED_ZONE]
   End If
Loop
Procedure CREATE_MENU
   Reset Zone
   Clw
   Print Zone$("Article 1",1)
   Print Zone$("Article 2",2)
   Print Zone$("Article 3",3)
   Print
   Print Zone$("End",10)
End Proc
Procedure CHECK_ZONES
   'Check is the mouse is over a zone and if the left mouse button has
   'been clicked (the left button is bit 1).
   Repeat
      A=Mouse Zone
   Until A>0 and(Mouse Click and %1)
End Proc[A]
Procedure DISPLAY_ARTICLE[A]
   Reset Zone
   Clw
   'Print the article text here.
   Print "Article ";A
   Print
   Print Zone$("Back",1)
   Repeat
      Proc CHECK_ZONES
   Until Param=1
End Proc
The main loop generates the menu by calling CREATE_MENU which uses Text Zone$().  CHECK_ZONES then waits for the user to click one of the menu options.  If it's not the "End" option, then DISPLAY_ARTICLE is called to display the article using Print statements.
Give it a try and tell me if it's what you're looking for.
puni_gds
« Reply #2 on: January 28, 2007, 07:03:32 PM »
Hi Sidewinder,
Thank you very much for the solution you gave me to the problem I had. I gave your source a try and it was just what I was looking for. Cheers and thanks again! :)
